Xjs ignition problem
Hi not long had a v reg 1999 jag xjs. The other day I put disconnected the battery to weld the wing up and fill it. I pug the battery back on after to find the ignition is playing up and the car won t start. With the key out of the car the indicators stay on and there warning comming ie abs fault, and various other ones. When sit in the car the and press the brake the ignition comes but won't turn over ect help please many thanks
Can you verify the year and model? There was no 1999 XJS.
Cheers DD |
hi sorry its a xj sport v8
I suspect a fried Body control module but that's just a guess.
Post in the "X308" section for some decent advice. Cheers DD |
I should've said "XJ8 XJR 1998-2003" section
Cheers DD |
| All times are GMT -5. The time now is 08:02 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
