Air Con recommendations
Hi all, My air conditioning is not cool! I took it in to In 'n' Out in Stockton and they re-gassed it. It was really good, ice cold, for a day or two but did not last long.
I'm guessing that, as it got so cool after re-gassing, that all is OK except for the gas leaking. Took it back but they said they only do a simple leak test, which seemed OK, but I need to take it somewhere with higher spec testing gear. They did offer to re-gas it after the leak was fixed. My question is, does anyone have any recommendations where I should take my hot cat to get it sorted? I saw Jagtech recommended on a different page and wondered if this is the place to go. Any suggestions welcome. Thanks.
Forgot to mention. I connected up to an iCarsoft OBD tool and am getting a code B1B78. I think this is low system pressure. The system pressure is reading 37.5 kPa which i think is about 5.5 psi.
mosesbotbol (09-21-2021)
MarkyUK (09-21-2021)
I must have missed this thread when you first posted but would have recommended Jagtech Ltd in Stockton-on-Tees. Best independent in your area.
The following 2 users liked this post by GGG:
mosesbotbol (09-21-2021),
Ruts XK (09-21-2021)
x300newb
05-13-2010 12:59 PM
