2007 XK Base Radio Issue
Hey guys,
I have an 07 XK with the base radio (stock)
My left front door speaker comes in and out relating to big bumps on the road. I have removed the door panel to check the connections there and all seems good. Where is the amp (if there is one) located so I can check those speaker wire connections, or is everything built into the head unit in the center dash in a typical head unit location?
Thanks,
Brett Horton
Thanks,
Brett Horton
Received 1,893 Likes
Guess I'm wrong, see response #5 by Cambo in this thread:
https://www.jaguarforums.com/forum/x...rk-xkr-192195/
Brett,
That's part of the Audio Connectivity Module, a dealer-installed accessory to provide iPod connectivity for pre-2009 models. Beginning with the 2009 4.2L XK/XKR models, Jaguar introduced iPod connectivity that was integrated with the touch screen and steering wheel controls. See: https://www.jaguarforums.com/forum/x...ve-box-161157/
Stuart
Stuart
jbretthorton (01-18-2018)
I kind of meant that really.
I have had the pleasure of removing the glove box 4 times. Once to put the ACM in, once to take it out because it wrecked the FM reception for some of the radio stations with weaker signals. Then I put it back in again when I discovered Spotify and finally to fix the damper mechanism.
