2011 XKR Radio Replacement
There is issue with the CD player in my 2011 XKR, it seems that there is a CD stuck, it looks like it has warped or bent somehow.. How easy is it to replace the radio ? I can get one from LKQ or EBay for $100 if the CD has damaged the mechanism. Thanks.
Well, if only ONE has stuck, use the other five slots.
Won't move at all . Needs to be replaced or repaired.
It's all in the Workshop manual.
https://cimg2.ibsrv.net/gimg/www.jag...22f52f8cba.jpg https://cimg1.ibsrv.net/gimg/www.jag...3a109eb691.jpg |
Thanks, just downloaded the manual. Look like a straight forward job thankfully.
It's easy to do. I had to remove my radio when I removed the dashboard. Just make sure you unscrew the correct screws.
Thanks,
