Sponsored by: DashLynx
Adaptive Dynamics Fault.
Old 07-17-2016, 06:15 AM
jimbov8's Avatar
Default Adaptive Dynamics Fault.
Does anyone have a picture, or can tell me exactly where the sensors are for this system.
I have the warning on the dash. Cleared once before by pulling the fuse and the refitting. Perhaps coincidence. Now on constantly and my code reader cannot see it.
Battery is maintained constantly on CTEK so I know that is not the problem.
Only other thing I've done recently is remove the undertray to check for a leak so perhaps I may have disturbed something when refitting, as this is when the warning became permanent.
Thanks in advance for any useful information.
Old 07-17-2016, 07:19 AM
Received 4,436 Likes on 2,421 Posts
Maybe this helps X150_2006-2009_Adaptive_Dynamics.pdf
You really need to scan the car with an IDS or SDD, or maybe one of the other aftermarket scanners that can see B, C and U codes.
Without codes, you are kind of shooting in the dark.
The following 2 users liked this post by Cambo:
guy (05-03-2017), jimbov8 (07-17-2016)
Old 07-17-2016, 07:39 AM
m20nuts's Avatar
I have just fixed mine without a code reader. I had the permanent yellow triangle on the dash.
The system is quite simple. There are four sensors, one at each wheel and three accelerator sensors. This goes into a control module behind the rear seat that then sends the voltage to each shock absorber.
Get the wiring diagram and have a look. I traced mine to a faulty suspension height sensor. At the control module , 5 volts is sent out to power the sensors and a signal is returned. On mine, 2.8v was coming back from three sensors but one was at zero.
I unplugged the module and checked the resistance between ground and the signal from each sensor. Three were about 470k ohms and the faulty one 30 ohms. To make sure it was not a wiring short, i disconnected the faulty sensor and measured again. Thai time the resistance went to infinity. I then measured the sensor it self and saw the low resistance there too so I knew it was faulty.
I also checked each actuator coil from the shock absorber and these all read about 2.8 ohms and all the same so i knew these were fine.
One final thing I did was unplug the faulty sensor , bridge an output from a good sensor to the faulty ones input on the control module, then start the car.
I got no yellow triangle and was able to select winter and dynamic mode which I wasn't able to do when it was faulty
I finally got a second hand sensor from a XF and fitted it and all came good.
So it can be done with no code reader , it just takes a lot more time to do but is more satisfying.
If you need help, just ask as you do have to be handy with a multimeter
The following 6 users liked this post by m20nuts:
jimbov8 (07-17-2016), macon6500 (04-12-2021), Nigwel1058 (03-03-2022), Overkill (03-19-2020), Panthro (02-27-2018), Queen and Country (05-03-2017) and 1 others liked this post. (Show less...)
Old 07-17-2016, 09:29 AM
jimbov8's Avatar
Thanks guys, gives me something to be going on with.
Thanks Cambo but mine is a 5.0L version.
Old 07-17-2016, 05:38 PM
Oops I read the 2009 bit but missed the 5.0L, here try this one 2010_XK_Dynamic Suspension.pdf
jimbov8 (07-18-2016), tberg (08-09-2016)
Old 07-18-2016, 02:41 AM
jimbov8's Avatar
Thanks Cambo that's exactly what I was looking for.
Old 07-18-2016, 04:06 AM
tampamark's Avatar
This is an advanced level troubleshooting lesson! Well done.
Old 07-18-2016, 06:00 AM
Or if you had a code reader which reads chassis codes it would have told which sensor was open circuit
But old school trouble-shooting shouldn't be shunned either
Overkill (01-01-2020)
Old 07-18-2016, 09:04 AM
tampamark's Avatar
You kids and your fancy toys...I use a map and compass instead of my gps. And cans with a string instead of a phone.
The one thing that really bums me out is my ice maker stopped working. Constantly filling old school ice trays is below average. I need your trick reader on that task darnit.
All in good fun!
Old 08-07-2016, 07:18 AM
talltim's Avatar
Just had this come on my 2010 XKR did clear once but perm active
scanned with sdd which is saying code U043A92 invalid date from suspension control module B
Was going to re programme module but thought better of it as car is under jag warranty at present
Where did you got to with your Jimbo?
Old 10-04-2016, 10:05 AM
jimbov8's Avatar
Default Resolved
Having finally got round to removing the back seats to get to the module, voltage checks pointed to the front right height sensor being faulty.
Disconnected the arm and operated the sensor by hand and found it to be very ratchety.
Purchased a new one, fitted and now everything is back to normal.
Now back to having some fun.
Old 10-04-2016, 10:19 AM
tberg's Avatar
Received 2,541 Likes on 1,412 Posts
m20nuts couldn't have said it better. I recently had the exact same scenario and it also was traced to ride height sensor, as he stated. That's where I would look first.
Old 05-03-2017, 01:11 AM
trkyam's Avatar
Thanks for all the information!!
Im having this problem as well but a little different,
ABS not available, DSC not available, Adaptive Dynamics not available.
Also it says my front right tire pressure is low, but I checked it by hand
and it is normal.
Where should I start? I have a multimeter, but do not have proper diagnostic tool.
Guidance please.
Old 05-03-2017, 02:46 AM
jimbov8's Avatar
To be honest, start with charging the battery and try again. If the faults remain then the next place to look would be the wheel sensors.
trkyam (05-03-2017)
Old 05-03-2017, 04:47 AM
trkyam's Avatar
Battery voltage is sat, but i'll give it a charge anyway,
there was some heavy rains i drove through lately, i'm thinking
one of my height sensors might have been wetted
Old 05-03-2017, 05:22 AM
jimbov8's Avatar
The height sensors are pretty much waterproof but it wouldn't hurt to check the connectors. It's the ABS warning that makes me think first of the battery and second of the wheel sensor.
trkyam (02-26-2018)
Old 05-03-2017, 05:39 AM
trkyam's Avatar
That makes sense! i will inspect the wheel speed sensors,
snap some pictures,
thanks
Old 05-03-2017, 08:10 AM
Queen and Country's Avatar
Received 2,380 Likes on 1,607 Posts
i
What a jewel of a contribution to Jaguar and its owners.
Its the sort of stuff they could put in the repair manual for dealer.
As in check here first.
Old 05-08-2017, 12:25 AM
trkyam's Avatar
I inspected all 4 wheel speed sensors, everything looks good,
after that I managed to get JLR SDD working, and did a full scan on my vehicle
Heres what I came up with:
I'm pretty clueless on what to do next.. help!
-Control module output power A Lost communication
with instrument cluster control module
-Front left wheel speed sensor
-Antenna circuit
-Front right height sensor
-Steering angle sensor
-Invalid data received from the suspension control module B
-Invalid data received from ABS control module Invalid data received from ABS control module
-Control module microprocessor B Park aid ignition Number plate lamps
Thanks in advance!
Old 05-08-2017, 08:19 AM
jimbov8's Avatar
First thing now you have them recorded is to clear the lot, go for a 30 min drive and then see what comes back.
From your list I would say your front left wheel sensor and front right height sensor are causing your problems.
Quick Reply: Adaptive Dynamics Fault.
