Advice needed for brake job 2009 XK
Old Sep 23, 2019 | 11:29 AM
badicedog's Avatar
Default Advice needed for brake job 2009 XK
good morning folks, It's time to replace my brakes soon. I have a few questions for you veterans that have done this before.
1. Can the factory rotors be "turned" machined? Or do I need to replace them at each brake job?
2. Is there any special procedure when dealing with the rear E brake?
I am considering using a brake kit from Hawk Performance, has anyone had any experience with this company?
Old Sep 23, 2019 | 11:39 AM
badicedog's Avatar
This is the specific brake kit I am looking at.https://www.hawkperformance.com/part...el=92594&note=
Old Sep 23, 2019 | 02:02 PM
mosesbotbol's Avatar
They can be turned a little, but not much. It depends...
The OEM rotors aren't that expensive luckily.
Old Sep 23, 2019 | 02:47 PM
nasomi's Avatar
There's apparently a special tool to retract the brake calipers. I tried doing it myself only to be left with massive and seemingly endless frustrations at getting the calipers off because the rotors were dished. In the end I put the wheel back on and took it into the shop.
Old Sep 23, 2019 | 03:24 PM
AlexJag's Avatar
Sponsor
At least to me , the brake change on the xkr was a straight forward , pretty easy job. Using a cheap $10 cylinder caliper compressor worked great , just keep on turning the cylinder with biscripts so it pushes down while applying pressure with caliper compressor.
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Sep 23, 2019 | 04:14 PM
gkubrak's Avatar
There is a service limit for rotor thickness. If they are at or below the service limit, they should be replaced.
If they are within spec and don't show signs of warping, then I would keep them.
If you undo the 2 bolts on the rear E-brake, you can split the caliper in half essentially and remove the rotor without having to mess with the cable or bolts going to the knuckle.
Be careful with the 2 pins and clip inside the e-brake when reassembling. And don't forget the e-brake reset procedure when you're done.
Old Sep 23, 2019 | 04:17 PM
Russ9898's Avatar
Release the e brake and then disconnect the battery when changing the rear pads. Once you have renewed the rear brakes reconnect the battery and follow the onscreen instructions on your dash to recalibrate the e brake to operate with your new brake setup.
Old Sep 23, 2019 | 05:45 PM
badicedog's Avatar
Thank you sooooooo much guys.. I opted for the Hawk performance Talon rotors with Akebono European front and rear pads. Now just waiting on delivery.
Old Sep 23, 2019 | 10:01 PM
CleverName's Avatar
Both my '07 XK and my 2010 XKR are pretty simple to do, and without disconnecting the e-brake.
The piston retraction tool is imperative, but my local auto store lends them out with nothing but a deposit.
The rear e-brake takes a little manhandling, and un-mouning the bracket holding the end of the cable from the caliper. but it is pretty easy after yo have done it once.
Hawk is a highly respected company. Sadly they do not make brake pads for our cars, or I would be all over them!
Old Sep 23, 2019 | 11:58 PM
badicedog's Avatar
Hawk makes rear pads for the XK but not front. I do believe they now have pads for the XKR
Old Sep 24, 2019 | 12:04 AM
George05's Avatar
I done a DIY change to all 4 corners , Discs (rotors ) opted for Padgid discs and pads all round cost was cheap under £500 , an indy had quoted me over £900 plus . I have a JLR icarsoft version11 so after putting car into service mode it was very easy to do
Old Sep 24, 2019 | 04:38 PM
CleverName's Avatar
Looked up my 2010 XKR and sure enough, they have a selection of front pads, but only for Alcons (which I dont have). This is certainly a step in the right direction, but without identical pads for the rear, I feel "front only" is a bad call.
Ah well, ya got my hopes up again!
Torino
Canada
Jan 9, 2020 09:56 AM
Zarathushtra
Jan 15, 2018 07:10 AM
dougsjag
May 5, 2014 05:31 PM
venom_99
67
Nov 23, 2012 12:09 PM
