Advice Newbie (handling/tuning)
Hi Chaps
Sorry if this has been asked a million times, I have read quite a lot of posts but can't find the exact answer. I'm looking at taking a 2012 XKR Cab at the moment. I'm coming from having a few of performance cars (GTR (32/33/34/35, Audi RS5, RS6, S5, R8, Jag XFR, Merc C63 AMG, Supra etc etc). I based in the north of England where it is wet a lot of the time. Now the question I have is around the wet handling, I've tested 3 XKR's and they all seem very twitchy when getting above 35-50% throttle. I'm not a hooligan (honest!) and tend to only really drive fast on track but sometimes it is important to have the confidence that the car is going to be stable when you have to get on the power. So I'm wondering if the cars were unstable due to tires, all the cars were running Dunlop tires 285 rear 255 front on 20" wheels or is it the characteristics of the car? Would different tires help? are there any other ways to improve traction? stability? Even on a straight with the salesman driving he started to accelerate from 35-40 mph it kicked down and the back end went out. The thing is I don't remember my XFR being like that don't get me wrong it would step out into over steer but you had to be really pushing on. PS could anyone point me in the right direction regards to tuning i.e After market ecu's? Engine tuning? Suspension? PPS What sort of power has the drive train been tuned to my XFR was running 580hp and had no issues. Would the drive train/engine take more than that and how much? Just thinking about when I do the odd vmax event. Sorry for all the questions! Smokey |
Maybe I'm misunderstanding you here, but the rear-end is stepping out on you, and you want more than the 510hp it already has?
In wet conditions, there's probably no tire that will contain that power. Others will probably chime in with their preferences for a dry traction tire. |
Yeah, you'd probably just need new/different tires (NEVER MICHELIN!!!). That won't help much though, when the skinny is mashed.
Firstly welcome to the forum.
Tyres are the big issue here, when I got my XKR it had Falkens on it which I'd previously had on an Audi S4 and thought they were a great tyre, on the XKR they were junk! I've since put on a set of Pirellis and it's made a world of difference, don't get me wrong, this car is definitely still traction limited but a good set of tyres is a must! Regarding tuning in the UK Spires is really your best bet (although I've no experience with them) there is also Paramount but they've had issues over the years. Sounds like you're no stranger to powerful cars so I won't lecture you but I'm not sure if you're after tuning that this car is the one for you due to the traction issue. The XKR-S has slightly wider rear wheels and came with 295 rear tyres rather than 285 to help this, but ultimately I think running more power than the XKR-S would be pointless, saying that if you were running 580hp in you XFR then you may be happy.:icon_shrug: Either way happy hunting, it is a great car! |
I have a plain old 2011 XK with Continental DWS 06 Tires on the 20" Kalimnos wheels. When driving normally in the rain I have no issues, and the Traction Control is quick to prevent wheel spin. There is also "snow mode" which will tone down the throttle response to give better control in bad weather. The 385hp of the regular XK is no slouch if you are more of a cruiser, and less of a racer :)
The rear end is too stiff in these cars. Softer rear springs and/or a stiffer front sway bar or softer rear sway bar is needed. There is almost no understeer engineered in. I've been meaning to do some research to see if someone makes an adjustable set of sway bars.
Originally Posted by flyc2c
(Post 1579374)
Originally Posted by SeanU
(Post 1578718)
Originally Posted by Jockster
(Post 1578502)
Originally Posted by Cee Jay
(Post 1578275)
Originally Posted by kj07xk
(Post 1578252)
Well there's a few things that are possible...
You can get a stiffer front sway bar https://www.jaguarforums.com/forum/x...ll-bar-167767/ the sway bars on the XK are the same as the XF, XJ, S-Type, F-Type. You can get adjustable sway bar links SuperPro Sway Bar Links Heavy Duty Adjustable TRC1085 fits Jaguar XK 5.0 XKR-S | eBay There's lots of options for coil-overs and lowering springs... Funny enough when Jaguar made it's "hotrod" models like the 2008 XKR-S, they put a stiffer rear bar on, and left the front one the same. The XKR-S GT also got a different rear bar, no changes on the front... There was also a camber kit for the rear to make adjustments (rear camber not adjustable from the factory) but damned if I can find the link now (it was a shim kit). As for tunes, there's so many options out there now from many different tuners... we have several as sponsors/vendors here on the forum... It's also possible to simply flash the XKR-S tune into an XKR (I've done a few of them now) but what you really need to do first is put the XKR-S center exhaust section in, it has an x-pipe instead of the resonator, it makes quite a difference on it's own. |
Originally Posted by Cambo
(Post 1579449)
You can get a stiffer front sway bar https://www.jaguarforums.com/forum/x...ll-bar-167767/ the sway bars on the XK are the same as the XF, XJ, S-Type, F-Type. You can get adjustable sway bar links SuperPro Sway Bar Links Heavy Duty Adjustable TRC1085 fits Jaguar XK 5.0 XKR-S | eBay There's lots of options for coil-overs and lowering springs... Funny enough when Jaguar made it's "hotrod" models like the 2008 XKR-S, they put a stiffer rear bar on, and left the front one the same. The XKR-S GT also got a different rear bar, no changes on the front... There was also a camber kit for the rear to make adjustments (rear camber not adjustable from the factory) but damned if I can find the link now (it was a shim kit). As for tunes, there's so many options out there now from many different tuners... we have several as sponsors/vendors here on the forum... It's also possible to simply flash the XKR-S tune into an XKR (I've done a few of them now) but what you really need to do first is put the XKR-S center exhaust section in, it has an x-pipe instead of the resonator, it makes quite a difference on it's own. Thanks |
(Post 1578275)
Originally Posted by SmokeyJag
Just out of interest why not Michelin? Ran CUP2 on my track car and they helped me towards dropping over a second off my lap time compared to R888's at one of my local circuits. What would you recommend? ........ The only GOOD thing Michelin did was return most of my $$$, almost enough to get the Hankook Ventus V12 EVO2 tires that I have now, and which are MUCH better than the MPSS that I had. It was funny; a fellow in this forum.... Queen and Country..... ragged me for MONTHS about my hate of Michelin. One day he apologized because the Michelin PSS tires he had.......... Fell Apart. Another funny thing... I left an HONEST review of the Michelin Pilot Super Sport tires on their website, but it was denied as "Doesn't fit our needs at this time." I guess the reason they are rated so high is that most the BAD reviews are discarded. Good Business Practice! |
[QUOTE=Cambo;1579449]...
There was also a camber kit for the rear to make adjustments (rear camber not adjustable from the factory) but damned if I can find the link now (it was a shim kit)... Really? I feel a parts-search quest beginning :icon_user: |
Shims are something like this http://www.aligncraft.com/parts.pdf there was someone on here with an X150 XK who got some shims from another vehicle to fit (a Ford or Lincoln from memory), but damned if I can remember who it was... you also need to shim the brake calipers the same angle as the main shim to get it properly aligned.
EDIT Or was it from a Volvo? Something from the Ford family I'm sure... |
[QUOTE=Cambo;1579449]Well there's a few things that are possible...
You can get a stiffer front sway bar https://www.jaguarforums.com/forum/x...ll-bar-167767/ the sway bars on the XK are the same as the XF, XJ, S-Type, F-Type. /QUOTE] I'm going to look into that front one! |
