Air con issues
AC compressor clutch does not engage when air con is turned on. Low side and high side pressures
Both at 80 psi 2009 xk |
OFF pressure for AC should be above 100 minimum. Seems you need a refrigerant service. Low pressure prevents stuff from happening.
Yep, regas. Make a note of where the connections are (on the //R one is under the air intake) so the tech doesn't suffer. Takes about 30 minutes for the machine to do it's thing, then blessed relief.
and for clarity's sake (doesn't change your problem) our a/c compressors are clutchless.
Originally Posted by Cee Jay
(Post 2094476)
Originally Posted by Spass
(Post 2097030)
How does one add refrigerant if the can pressure is not 100lbs of pressure?
I searched all over the place to get an actual PSI figure of a can of freon, damned if I can find any info anywhere. However, 100 PSI in a pressurized can isn't unheard of anyway. Them little buggers are really packed with stuff. |
OK I will give it a try this evening.
If this doesn't fix the issue, you may need the pressure valve thats installed in the compressor. Can be replaced separately from compressor. There is a TB for this issue.
Hi i've had the same problem on my 2007 and it's hub compressor problem. Look for if the hub iexist on your compressor.
good day. Marc |
