Alcon Calipers rebuild ...
Old May 22, 2018 | 02:57 PM
‘Oleguy's Avatar
Default Alcon Calipers rebuild ...
So I found out during the process of changing or attempting to change my brake pads that the calibers need rebuilding it seems that the Pistons are so corroded that if we just clean them up and push them back and put the new pads in that it’s going to cause the calibers to late for sure at some. In time. Does anyone know where to get rebuild kits or get rebuilt calipers these are the Alcon that are red with the are on them six piston front and four piston rear so I found out during the process of changing or attempting to change my brake pads that calibers need rebuilding it seems that the Pistons are so corroded that if we just clean them up and push them back and put the new pads and that it’s going to cause the calibers to late for sure some. In time. Does anyone know where to get rebuild kits or get rebuilt calipers these are the Alcon that are red with the are on them six piston front and four piston weird.
Jaguar wants $4200.00 for a new one front.
Old May 22, 2018 | 03:27 PM
jagtoes's Avatar
You need the part number of your caliper then search the net. I have seen 27mm pistons for $65 each . they also have seal kits. On line prices match the jag number.
Old May 22, 2018 | 05:49 PM
jahummer's Avatar
Alcon sells new seal kits:
FRONT:
https://alconkits.com/alcon-brake-se...eal-kit-detail
Rears are 31.8mm, haven't found any kits yet
https://alconkits.com/alcon-brake-se...-stripe-detail
wiper seal: snw3432x603
Old May 22, 2018 | 06:41 PM
Stuart S's Avatar
So I found out during the process of changing or attempting to change my brake pads that the calipers need rebuilding it seems that the Pistons are so corroded ...
How many miles on your 2008 XKR Portfolio?
Old May 22, 2018 | 07:13 PM
‘Oleguy's Avatar
FRONT:
Jahummer,
Thank you. I called Alcon USA after much searching. Located in Illinois. I spoke to owner Chris. They have a deal thats not too awful bad.
Send in 2 Calibers & 95$ that gets you tear down and the needed pats identified as well as return shipping. You are then notified actual cost to rebuild & pressure tested. 2-3 week turn around & average @ 250-300 per caliber.
I bought the car to do my own work as I turned wrenches for many many years. But with an option like that I have to think about it. I would just have to sell a few things I haven’t used in years.
But the rebuild kits for that cheap is awesome. Thanks again.
Qvhk
Nov 19, 2017 09:29 AM
MaximA
Nov 1, 2016 09:40 PM
SteveM
Dec 15, 2015 09:15 AM
Stuart S
Oct 12, 2015 07:45 AM
jp3872
Apr 23, 2014 07:40 PM
