All Aluminium Radiators?
Searched, but no give. I have a 2007 base model, Im gearing up to replace the raditor in a couple of months. I discovered a micro leak where the plastic meets metal. So Im wondering if anyone here has replaced the oem with a custom all aluminium piece. |
I managed to find a builder that can make a radiator for my XK, but the question about transmission cooler came up, and Im wondering if any of you have any input in this. One of the options is, to gut my oem radiator and use the stock cooler, but Im curious about external coolers and if this would be a better option on my base 2007 x150. Ideas are all welcomed! |
Interesting question, hope someone has experience there.
I would think a radiator shop would have no problem building a Trans cooler into a radiator these days. Its pretty common, and parts to do so should exist? Of note, if I were to have a custom built unit, I would do some serious measurements and see if there is room for an additional core on the front side. Vince |
Originally Posted by Brewtech
(Post 2011921)
Originally Posted by jagtoes
(Post 2012797)
I've had both brass and aluminium radiators built for the various engine conversions I've done. Most shops can build anything that you want but I wouldn't believe there is anything special about the XK unit. Also my bet is they can fix the one you have . The easiest thing to do with most builders is to bring them the original unit and have them replicate it. As for the trans cooler I would believe it would be better to have it built in and the same size/volume as OEM. You may not have enough room for an external mount and it may interfere with the AC condenser.
Originally Posted by JackJohn
(Post 2012901)
I agree with JT, you will be better served to stick with the JLR design. These cars do not like to be under or over cooled and will throw DTC's in either case.
(Post 2012901)
No such thing as an 'over cooled' engine. Not now, not ever... Engineers can only dream of such a possibility. All police vehicles in the U.S. use oversized radiators and have for 30+ years. That's why they can sustain high speeds for significantly longer than any base OEM. As I said, measurements would be everything. If it is impractical, so be it, but I wouldn't miss the opportunity to upgrade it it could be done. Vince |
Originally Posted by CleverName
(Post 2013822)
No such thing as an 'over cooled' engine. Not now, not ever... Engineers can only dream of such a possibility. All police vehicles in the U.S. use oversized radiators and have for 30+ years. That's why they can sustain high speeds for significantly longer than any base OEM. As I said, measurements would be everything. If it is impractical, so be it, but I wouldn't miss the opportunity to upgrade it it could be done. Vince Clever, I agree that Improved Cooling Capacity is a good thing. That would also include a properly operating thermostat. |
(Post 2012927)
My goal is to rid myself of a plastic topped radiator. Heat is forced to travel to the fins where there is air circulation. |
I'd just fix it or replace with OEM and move on. There will be plenty of other items to spend money on now or later with the car.
What keeps me trucking forward with all aluminium is that I can have it made for less than an oem. Original dimensions is probably best for me on this first try. I still think plastic is a cost effective way to mass produce 10s of 1000s of units to meet manufacturer demands. They have a lifespan, that doesnt meet my expectations for a car that I drive a lot in extreme temps 6-7 months of the year. |
