"Check Fuel Filler Cap"
Old 04-05-2008, 04:17 PM
GhostriderXKR08's Avatar
Default "Check Fuel Filler Cap"
Go this yellow triangle warning today. Opened the cap and made sure it's tightenedbut itstill displays on the dash. Anyone get this warning before? Bad Cap? Just curious before I bring it in on Monday. TIA!
Old 04-05-2008, 07:13 PM
Default RE: "Check Fuel Filler Cap"
Likely your dmtl pump is not sealing. If your dealer is any good they will run evap self test watch it fail then clamp off hose to pump. It will then pass. They should then replace the dmtl pump and canister assembley.
kenmicn (03-30-2019)
Old 03-30-2019, 09:04 PM
kenmicn's Avatar
Thanks; I am thinking the DTML pump the techs replaced needs to be replaced again or repair a hose....?
I will definitely follow-up.... Thank you again for your reply.
Old 03-31-2019, 12:51 PM
JagV8's Avatar
Received 4,483 Likes on 3,901 Posts
11yr old thread - now that's resurrection!
Old 04-01-2019, 03:36 AM
GGG is online now
Received 16,747 Likes on 12,140 Posts
............... and the OP has a 2009 XF Supercharged so it's also transmutation.
JagV8 (04-03-2019)
Old 04-02-2019, 10:41 PM
riverman's Avatar
Mine was the cap about 2 years ago.
Sqeeter91
09-04-2013 10:38 AM
YYZ
08-13-2013 10:59 PM
Perse1
05-05-2013 02:17 PM
Earnest
12-09-2009 07:22 PM
stevef
07-16-2008 12:40 PM
Quick Reply: "Check Fuel Filler Cap"
