Anyone ever 'chip' their XK?
#61
Cambo. No one ever said all Dyno’s measure the same. Just the same as all drag strip runs are not the same. Different track and different weather conditions, reaction times WILL yeald different e.t’s. You know that as well as everyone here knows that. So to say drag strip is the only true way is nonsense. I am pretty sure that everyone is aware that dyno’s all read differently dependent upon type, brand and operator etc. my point is not one tuner has ever released a before and after Dyno runs on the same dyno on the same day under similar weather conditions for these cars. If tuning was my business and I was trying to sell tunes to my customers, I would certainly use the dyno charts as validation of my work. Unless of course, I had something to hide. Now, I certainly am not saying this is the case with your tunes and they may very well be the best but my understanding is that it takes maybe 30 minutes to install a tune yet not one tuner has published before and after results on the same day on the same car and same dyno for our cars. What are your claims for your XKR-S tunes ?
MarkyUK (02-15-2019)
#62
Mufc, I think you are missing a couple huge points. As has been mentioned in several other threads, no one really understands how Jaguar built the tune for these cars. There are layers of variables that need unraveled and sorted out to determine if changes actually improve performance or just push the power plant closer to 'boom'. What a lot of the F type folks found out to their detriment was some tuners really didn't have a grasp on what they were tweaking which put the engines at risk. That's where the XKR-S tune comes in. It was factory designed and once copied could be sold as 'Custom' or at least the basis for a custom tune. Again, Jaguar did not share any info with the aftermarket like Ford did in the early 2000's so it's all guesswork about what variable hold what factor of control over the basic tune.
I would hope and almost expect there would be a ton of relevant experience out there for my '07 Since it's been on the street for 10 years but there doesn't seem to be much and certainly not much that goes beyond a sales pitch
#63
Sounds like a figure that's been plucked out of the air.
No it doesn't. I've flashed Steve's XK and my XKR several times. KessV2 does not require removal of the PCM from the car, it's done over the OBD port. I'd expect the guy who runs the "Remapper Certification courses" to know this....
It is unfortunate that while trying to help and provide some information for those that are interested in remapping I feel I have to defend myself against an unexpected and unwarranted 'attack' from a moderator. I remap over 500 vehicles a year. It is a full time job, not a hobby. If I have permission to state my company name I'll do so, and you'll see every review on Google Reviews is 5-star. If anyone wants to contact me I'll be happy to help but I won't take advantage of a forum by blatantly advertising. I'm mainly here as a fellow Jaguar owner rather than for business.
#64
I had my 12 NA vert dynod after installing a Myna exhaust and having ECU Tuning group perform a tune. the BHP was 438hp as opposed to stock at 375 bhp. If you like to see the dyno sheet I can post it. About a 16% improvement. Unfortunately I didn't dyno the car before the modifications were. made.
#65
Your 2007 XK is now 12 years old and a lot of different things can happen during that time to cause a loss in performance. Before doing a tune, get your XK thoroughly checked out by a competent Jaguar technician.
Several years ago, I noticed that my XKR felt a little sluggish, but I didn't have a CEL or restricted performance warning. I was still under warranty and had my dealer check it. They found that one catalytic converter was partially clogged and replaced it under warranty. It didn't feel like the same car afterwards, and had much sharper throttle response. Doing a tune before replacing a bad catalytic converter would be throwing your money away.
#66
#67
Thanks for the response. I think the cats are OK since the car seems to move good enough. It's not terribly sluggish. What I'm looking for is a little more crispness in the throttle. Maybe I'll just put my foot in in a the pedal little more. (Smashing the pedal does seem a bit excessive.)
Yet to go back since installing the large throttle body and shorter diff ratio
A tune is definitely worth it and now on par with the 5l n/a
#68
I know I could eventually buy an XR but I will be happy to get my 4.2 N/A running at its optimum best. That would be good enough for me. Once the car is tuned I'm hoping it will have a more responsive gas pedal and launch the car from 0 to 60 in well under 6 seconds.
#69
For example if you change the exhaust and fit high-flow cats, and leave the stock tune, you will probably lose some throttle response, because the backpressure in the exhaust is one of the values used in the torque calculation by the PCM.
After fitting the Maxbore throttle body to Steve's XK the car would not idle properly, the tune had to be adjusted for that, and it took a fair bit of time to sort it out (measuring the throttle body, calculating the surface area, etc).
#70
Just had a read back through this thread, I had to laugh...
Add 12.463 @ 115.36 with a 1.959 60ft to that progress report.
I got it to trap 115.5mph a couple of times as well.
And this actually happened LOL, u102768 ended up with 11.930 @ 121.3mph on the slip from his 5.0L XKR
Who needs dynos...
Who needs dynos...
#71
I have looked into remapping my car (XKR-S) and have contacted many, many tuners. NOT ONE OF THEM have any meaning full data about what their "tunes" offer. The standard answer is "around 50hp for the supercharged cars" IF these "tuners" really did develop the tunes they would surely have dyno graphs of before and after the tune with the same dyno being used with similar weather conditions. How could they possibly re-map the cars without any dyno records ?? Not one tuner publishes any improved performance figures. Why ? Because any gains are almost imperceptible at WOT.
I think all of the tunes, as far as the supercharged cars are concerned, is simply a download of the standard Jaguar XKR-S tune (which Jaguar developed and not the tuner) and it is installed on an XKR. There might be some improvement (maybe 15 or 20 hp with the tune alone)but no way is there 50 hp difference with the tune like all of the "tuners" claim. Even with a pulley change I very much doubt that there is 50hp to be had on the XKR-S, XKR and not even 15hp on the N/A cars.
Until someone proves otherwise, my opinion is spend your money on stickier tires and better brake pads if you want to go faster. There are proven result to be seen with tires and brakes and not with any of the tunes for our cars.
If any tuners want to back up their claims of around peak 50HP or even 50hp under the curve, I will buy their tune and do a before and after dyno test and publish the results on this forum. Any takers ?
and yes our cars can be reflashed through obd2
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
#72
Saw an XKR 5.0 dyno 505WHP (I believe) at Eurocharged Orlando on their tune.
Had my XKR running VelocityAP and it was a massive difference vs. stock. Not even the same car. When I traded the XKR for the R-S, I can tell that the tune on my XKR was a modified R-S tune.
With VelocityAP, you're getting about 575HP (which is basically the SVR state of tune). Add the pulley, you're at ~600.
#73
I know that there isn't much point comparing results from different dynos but my '10 XKR had just under 503 WHP with just the XKR-S tune and the XKR-S mid pipe on it so I would have hoped for a little more from a tuner, especially if a smaller pulley was put on the car as well.
#74
For years tuning companies were claiming xxx horsepower from the cars they tuned, showed dyno sheets with "great" numbers on them, but the actual performance of the cars never matched up.
"Tune + pulley 630hp" but when people took them to the track they didn't run any faster than stock!!!
It's gotten to the stage where dyno sheets aren't worth the paper they are printed on.
The 1/4 mile trap speed is the only proof of horsepower that I have any faith in, it's pretty simple physics and the methods apply across the board.
If your 4.2L XKR is really making ~500hp then it will trap 115mph, like mine does.
If your 5.0L XKR is really making ~600hp then it will trap 121mph, like u102768's does.
I don't care what a dyno sheet says, those are the real world numbers that cannot be fudged.
#75
My last time running XKR at Vegas I ran 12.6 and 110.3 ,not including that Vegas track is up the hill plus strong head winds that day, da correction only is actually 12.47 and nearly 2 mph higher. Plus my car is a convertible and weights 100lb more than a coupe, which is aprox 1/10 of a sec difference in weight alone on a 1/4mi. Density Altitude is why most drag racing records are set during fall when air is dry and cool and near sea level , but not too cold where you loose traction. Bottom line DA is very important as well as track conditions. Dyno is definitely a more consistent and precise tool to measure HP and not a track where there are too many variables and why manufacturers use a Dyno machine and not 1/4mi to get power figures.
__________________
The following 2 users liked this post by AlexJag:
BlkC4t_XK14 (02-25-2019),
MarkyUK (02-21-2019)
#76
What a breath of fresh air some of the new comments are. For years and years I have been telling my customers that the road test is more important that dyno figures. Most drivers want to feel improved responsiveness and low-end pulling power improvements in particular.
The most common pre-remap request I hear goes along the lines of 'if it improves power at high revs, and once the car is going, that's great, but can you make it go when I tell it to and get rid of, or reduce, the lag". That is why I have always promoted a post-remap road test before payment, and why I offer a 30-day money back guarantee, I must add I also fully understand why drivers are sceptical about claims without seeing dyno results but by the same token dyno results are very easily manipulated, whereas a road test by the owner is definitive.
My own XK 5.0 responsiveness and low-end power improved dramatically after the remap. I will get it back on the rolling road in April or May (after it comes out of Winter 'SORN' which, for non-UK drivers, that means it is declared off road at the moment to avoid paying road tax in months I am not driving it) and will publish the Dyno results here. If anyone would like to attend to verify the test they're welcome to contact me.
There are owners that care about the numbers on the chart, and there are owners that care more about the on-the-road experience and drivability. In reality, it is the latter that really matters, but I'll get that Dyno read-out up as soon as my XK is back on the road after avoiding the winter salt! Until then, please bear with me.
Cheers.
Paul
Cheers.
Paul
#78
#79
Although I currently own a 2014 J, I just purchased a 2015 XKR convertible. It currently has no mods. Based on this forum I my add an x pipe and air intake. With that stated, should I go for an ECU remap or the less expensive and unidentifiable "Chip tuning" (still under warranty). Any recommendations on either. Keep in mind I'm in Chicago so it will be a DIY.
#80
I wouldn't be a bit skeptic, i have my 4.2 xkr done twice by Black Code remapping, and it is a bullet, i never had it on a dyno as i seen to many bad videos so that's a no go. 25hp i would say is an understatement, mine has had the top pulley done, exhaust system and mapped twice and the power is unreal., way above 25hp gain i would say. Is is neck wrenching through the gears and throttle response is amazing. Did cannonball ireland few weeks ago and i blitzed every 5.0 xkr there, left them so embarrassed , there also was on f-type r which was left by the waste side too. Not bad for a 2007 car.
Hi Powerhouse, where did you get it done? I'm in Ireland myself and I was looking for someone with a bit of experience on these cars.
