Battery flat, even with C-Tek -so what's the point???
#61
Very interesting. The same service manager told me that when batteries are replaced on 2010+ XKs, most times the charging system is never reset. He said it does not change anything. I remember reading a post or two from forum members replacing their 2010 XK batteries on their own with no consequences without resetting the charging system by Jaguar.
#62
As a note here I was told the battery has 85% of service life left before needing replacement. But was also told that they like to replace at 25% of service life. It maintains 12.7 volts off of the Ctek for more then 24 hours. How they measure service life , I don't know but was told that they get that information from the OBDII port on their system. As I get my annual service in April I'll see what happens next year at this time.
#63
#64
The battery had just come off the CTEK recondition mode but was driven about 15 minutes, sat in the parking lot, disconnected from the car, sat on the cart for about 30 minutes before their analyzer was used. The original spec I believe was around 800 CA, T8-90. The tester did a print out of all of the parameters and they were all in spec. Did the CTEK "fix" the battery for another 4 years of life? Was their tester faulty? Is there a problem with either the electrics in the car or the CTEK? Guess I won't find out unless the new battery fails sometime in the not too distant future
The Interstate batteries are made by Johnson Controls in Germany just like almost every other one out there.
So, your battery is specced at 800A but the tester showed 1100A after four years of service? Well, YMMV but I would certainly be having an interesting conversation with the staff about that or be looking for another shop.
As far as Interstate and Johnson Controls go - they certainly seem to own a lot of companies and manufacture all over the world including it would seem the US and Mexico so why they would bear ship costs of that weight from Germany seems odd. Still - if yours was definitely of German manufacture I guess you just got unlucky. Hope this new one works out for you but, last word, Ctek is quality kit and if you stick to it and good quality batteries you will not go wrong.
#65
Calibration
Periodically the BMS module will instigate a self-calibration routine. To self-calibrate, the BMS first charges the battery to its full condition. Once the battery is fully charged, the BMS will discharge the battery to approximately 75% of its full state of charge, but never lower than 12.2 V. The time taken to complete this part of the routine is dependent on the electrical load on the vehicle and the length of time the vehicle is used.
When the second part of the routine has been successfully completed, the BMS will return the battery to its optimum level of charge. The optimum level of charge will be between 12.6 V and 15 V, depending on battery condition, temperature and electrical loading. This process is run approximately twice a year.
If the vehicle is only driven for short periods the self-calibration and charging process could take a number of days to complete.
#66
Jagtoes....Please read post #60. Did you personally and recently check your battery's voltage disconnected from car and off of Ctek on it's own? If the dealer told you the battery is at 85% of service, how could it show 12.7 when 12.66 is the norm for a 100% service life? Let us know. Just curious. Thanks.
#67
A battery specified as having an 800A starting capability, but which a tester shows has an 1100A capability? Seems a bit odd, to say the least.
May I suggest a possible explanation - and I will be happy for someone much better informed than me to correct me if I am wrong!
Modern electronic testers do not actually discharge the battery. They measure the internal impedance with a small AC current / using a 'Wheastone bridge' technique (depending whose write-up you believe) and having determined the internal impedance (an indication of the degree of sulphation and other deterioration) then calculate what proportion of the original, specified starting current capability the battery is still able to provide.
That is why one of the bits of information you have to feed into the tester is the originally specified starting current capability, as declared by the manufacturer and stated on the battery. If this data is not entered correctly into the tester, the result shown by the tester will not be correct. This may be what happened on this occasion.
#68
I purchased it at Advanced, H8AGM, manufactured by Johnson in Germany but is the same spec as every other battery like it that I looked at marketed under other names.
So far so good here, thank you!
#69
#70
They did not correlate the service life to any specific voltage. Before I went to my service appointment the car had been on the Ctek for a few weeks. The step 7 maintain charge on my Ctek is 13.7 volts. Driving the car on it's 90 mile trip to the dealer the voltage varies between 13.4 to 12.7 on the road. The battery check was done with the voltage in this range. Now after driving the car back home and pulling into the garage I plugged in my volt meter and it was 13.2 volts . The next day after not being on the Ctek it was 12.7. 85% of service life doesn't mean 85% of 12.6 volts. Also my volt meter only goes to 1 decimal place.
#71
#72
Diagnostic Battery Charger for North American Cars ? Midtronics GR8
Also as an update, the new battery may have fixed the TSD backlight issue I had before BUT now I have a recline problem with both front seats. Not sure why, never had that problem before. Go figure.
#73
Another update - question?
So about about a week has passed since I took the car out, been on the Ctek with doors double locked. Drove for about an hour and the Ctek status indicator was flashing yellow when I came home. Plugged it in and it is now going through the standard laborious one step at a time.
Would this be an indication of anything out of spec?
#75
jahummer (05-10-2018)
#76
I’ll add that this is nothing out of the ordinary. The Ctek did the same thing with the previous battery for the last 3+ years. But Inwould think with a new battery it should not do this. Also previous drives with this new battery the indicator still flashed green so this is the first time it dropped to yellow.
#77
#78
I would look for 14.4V. If much lower, that might be contributing to the 12V battery's short service life. Also see what it is as the engine speed revs up to 2,500 - 3,000 RPM.
I would also measure the quiescent current draw when the car is IG-OFF and locked. It is supposed to be less than 0.035A (35 milliamps) after more than 15 minutes has elapsed after the car was locked. If much more, that parasitic draw is taking some power from your battery charger which therefore cannot maintain the 12V battery charge to the extent expected by the charger.
#79
