Battery issue
Old Jan 2, 2023 | 08:38 PM
u102768's Avatar
That is good advice and all I find I have to do with my '10 XKR but there isn't a continuous drain if you don't lock it, it just take longer for everything to shutdown which may ultimately run the battery down to the point where you start getting all sorts of weird electrical glitches from modules that don't boot up properly or in the right sequence.
Old Jan 2, 2023 | 09:24 PM
Stuart S's Avatar
Originally Posted by skywarrior
On my 2007 VDP, the manual advises to lock the car when not in use. If the car is not locked there is a continuous battery drain from all of the sophisticated monitor circuits.
Welcome to the Forum. I see that you just joined and your signature shows that you have a 2007 XJ8 VDP.
This is the X150 Forum, for 2007 - 2015 XK/XKR models. Your 2007 XJ is an X358, and that Forum is here: 2003 - 2009 XJ Forum (X350 & X358)
I noted that the post you replied to is almost 9 years old, and I suspect that was a mistake. If you posted your comment after having scrolled down to the bottom of the page, you became a victim of the Forum's Infinite Scroll feature, which takes you to older, related threads.
Charles1122
Oct 25, 2022 06:43 PM
Jagstefano
Dec 26, 2018 04:25 AM
muskox3437
19
Oct 13, 2016 09:52 AM
Cadillac
General Tech Help
Sep 23, 2014 12:39 PM
Cajuncat
25
Oct 17, 2011 10:21 AM
