Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK / XKR ( X150 ) (https://www.jaguarforums.com/forum/xk-xkr-x150-33/)
-   -   Catback Exhaust While Retaining Active Functionality? (https://www.jaguarforums.com/forum/xk-xkr-x150-33/catback-exhaust-while-retaining-active-functionality-222536/)
mushroom09 Aug 30, 2019 08:25 AM
Hello All,
I've searched to see if this specific question has been answered and didn't find anything. I'm interested in getting a little more noise out of my 2011 XKR175 by installing an aftermarket catback exhaust, perhaps a custom one from a local shop. I understand that certain options like Spires have the ability to retain the active exhaust valve functionality, but they are quite expensive. I was wondering whether it is possible to install a new exhaust system downstream of the baffles so that the functionality is retained. I'm also wondering whether this functionality would be as robust as it was previously since the system would not be optimized for this specific configuration. Has anyone done this who can comment on whether or not the aftermarket system was still quiet on the highway when the valves are closed but louder than factory when open?
Thanks!
-mushroom09
TexasTraveler Aug 30, 2019 08:51 AM
I cannot remember if the 175 came with the PAE mid-pipe X-Pipe , but if it didn't that could be an option for you. By removing the two mid-pipe resonators and replacing with x-pipe, you should hear an increase in your exhaust.
Stuart S Aug 30, 2019 09:14 AM
If you already have the PAE and want more noise, consider an exhaust cut-out. See: https://www.jaguarforums.com/forum/x...valves-217000/
mushroom09 Aug 30, 2019 10:48 AM
TexasTraveler: I'm not 100% sure but I don't think I have the performance active exhaust, just the standard for the XKR. I'll look into the X-pipe. Would that not cut out the area of the exhaust that includes the active valves?
Stuart S: I'll look into the exhaust cut-out, although I don't think I have the PAE.
Thanks for the help!
TexasTraveler Aug 30, 2019 10:51 AM
mushroom, the PAE X-Pipe is the mid-pipe section in between the cats and the active valves that are apart of the backbox (muffler)
https://cimg4.ibsrv.net/gimg/www.jag...9dad0a64c2.jpg
mosesbotbol Aug 30, 2019 02:31 PM
I would just spend the money for a proper well designed exhaust. Jag is not a car to roll dice on a home made exhaust. If you ever sell the car, you'll still get 50%+ the price of selling that exhaust by itself.
mushroom09 Aug 30, 2019 04:54 PM
That makes much more sense, thanks for the pic!
-mushroom09
Ngarara Aug 31, 2019 07:56 AM
The x-pipe PAE does make a difference - when the active valves are open, it's basically open pipes from the cats. But it's still acceptable and drone-free when the valves are closed.
badicedog Sep 3, 2019 05:19 PM
When I switched to 200 cell CATS the exhaust note and decibel increased.
© 2026 MH Sub I, LLC dba Internet Brands
