Convertible top will not close in auto or manual
Old Sep 24, 2012 | 04:42 PM
jetpilot1's Avatar
Cool Convertible top will not close in auto or manual
Convertible top will not close in auto or manual.
I have a 2007 Jag XK convertible and when I try closing it automaticaly it will come withing about 10 inches of the winshield and stop. It is also swinging the locking hooks at the end of this sequence to early and about a foot from it being within range of locking on the windshield. I have been able to successfuly manual close the top in past by using the allen wrench in trunk turinng it counterclockwise and pulling cable then wrenching down from inside on the top of convertible top, but this time it does the same thing as it does in auto mode and swings this hooks to early and freezing up about a foot away from the windshield. I can manual stow the top with no problem and have disconnected battery and resequenced the main windows then run the auto mode to bring up the bonnet to close position many times and I get the same result every time. Any help is appreciated.
-T
Old Sep 24, 2012 | 06:26 PM
Robert Page's Avatar
My wife's 2007 XK had the same problem and had to had motors and servo's replaced thankfully under warranty! Sorry to say you need to take it to the dealer or a good independent service shop.
Old Sep 24, 2012 | 06:55 PM
Rahtok's Avatar
I don't know about the 07s, but on the 10s, if the top gets confused you have to reset the cpu (yes, computer) that controls the top. You do this by disconnecting the battery for 10 minutes and then, after manually lowering the top (and relocking the pump) take it back up again. It's kinda convoluted to find how to do it, but is actually simple in operation once you know.
Step 1 -- lower top all the way.
Step 2 -- relock top pump with the allen wrench
Step 3 -- disconnect battery
Step 4 -- drink cocktail ( <-- important step. helps keep you calm in the event you have to redo the steps)
Step 5 -- reconnect battery
Step 6 -- enjoy top up motoring again.
Old Sep 25, 2012 | 05:05 PM
jetpilot1's Avatar
RahtokI don't know about the 07s, but on the 10s, if the top gets confused you have to reset the cpu (yes, computer) that controls the top. You do this by disconnecting the battery for 10 minutes and then, after manually lowering the top (and relocking the pump) take it back up again. It's kinda convoluted to find how to do it, but is actually simple in operation once you know.
Step 6 -- enjoy top up motoring again. RahtokI don't know about the 07s, but on the 10s, if the top gets confused you have to reset the cpu (yes, computer) that controls the top. You do this by disconnecting the battery for 10 minutes and then, after manually lowering the top (and relocking the pump) take it back up again. It's kinda convoluted to find how to do it, but is actually simple in operation once you know.
Step 6 -- enjoy top up motoring again. Thanks Rahtok
Old Sep 25, 2012 | 05:13 PM
jetpilot1's Avatar
Default Convertible top still freezing going to close position
Thank you Rahtok for the sequence, I tried this but it didnt work. Im noticing that once the button is pressed. It takes a full 13 seconds for the top to even move and once it does, it will still freeze at about a foot away.
Old Oct 8, 2012 | 03:27 PM
mascott's Avatar
I am having the same problem on my 07. The door was left open and the battery was drained. Now the top will not function properly. The top cover will open but the top will not come up. The pump is very hot at the top where it is black. Looks like an electric servo. I wonder if it is electrical?
Sprayall
May 30, 2021 08:13 AM
reedmtn
Sep 5, 2015 08:04 AM
Sprayall
Sep 3, 2015 07:49 PM
pnwrs2000
Sep 3, 2015 11:55 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
