Curb weight
According to my manual my 2014 XK coupe weighs 3516 pounds... When I searched the curb weight online that usually comes up a couple hundred pounds higher for the XK and the XKR.. Also curious what the actual weight of the 07 08 09 XK and XKR is...
That's 110 pounds I'm grateful to have!
Also, many truck stops have weigh stations that will let a person weigh their car for like five bucks. Also dumps, salvage yards and recycle stations have scales available. |
Isn't curb weight stamped on the door plate?
Keep in mind kerb weight is with full fluids, full tank of gas and dry weight is without all fluids. I only mention this as some sources online MAY confuse the two.
https://cimg7.ibsrv.net/gimg/www.jag...02ff795622.jpg
here's a better pic of the manual if you add the curb weight of the front and rear wheels that comes out to the actual weight they're showing |
I do recall reading about the 2010+ being heavier then the 07-09 (4.2) ..however
With just over a 1/4 tank , 20" senta and no space saver the xk 4.2 weighed in at 1675kg The xkr portfolio (Alcon) weighed in roughly 75-80kg heavier then mine so it was around 1760kg All weighed at WSID |
