Sponsored by: DashLynx
Adaptive Dynamic Mode Fault
Old 12-09-2015, 09:49 AM
2013XK's Avatar
Default Adaptive Dynamic Mode Fault
Hi,
Anyone get a dynamic mode fault? I had H&R lowering springs installed yesterday and now I'm getting the error code "adaptive dynamic mode fault" and the dynamic mode is not working. The Installer reset the height sensors to factory but the code is still there. If I clear it will the dynamic mode start again?
Old 12-09-2015, 11:44 AM
jagtoes's Avatar
Received 1,836 Likes on 1,231 Posts
If you get a fault after someone has made a change then it appears something was missed or hooked up wrong during the installation. I would go back to the installer and have them recheck their work. Also erase the codes and see if it comes back. Where there any other codes?
2013XK (12-09-2015)
Old 12-09-2015, 12:04 PM
2013XK's Avatar
No other codes. I'm bringing it into the dealer next week to clear the codes. Hopefully it will be a simple fix.
Old 12-09-2015, 12:36 PM
Guille's Avatar
There shouldn't be any codes when lowering. Only issues may arise is with the adaptive cruise control. What wheel size do You have? That could be the issue as well or they didn't plug the dynamic dampers back in.
2013XK (12-09-2015)
Old 12-09-2015, 01:05 PM
2013XK's Avatar
Thanks Guille. Good to know its a correctable issue. I have 19's in the front and 20's in the back.
Old 12-09-2015, 01:39 PM
SeanU's Avatar
Check the connectors on the body height sensors in the wheel wells as well.
2013XK (12-09-2015)
Old 12-17-2015, 12:14 PM
2013XK's Avatar
Default update to H&R lowering springs 2013 XK
So I brought my XK to the dealer and they cleared the codes but the adaptive dynamic fault code came back. Now they can't figure out what's going on. The H&R Springs website says the srpings lower the car approx. 1.3 inches but the suspension shop said my car was lowered 1.6 inches after install. I'm thinking that's too low and the dynamic mode is seeing it as the car bottoming out. It rides like a brick right now. Does anyone know at what point does the dynamic mode bottom out? Does it have 1.5 inches of play for example? If I added spacers would that help? The dealer has me scared I ruined the car.
Old 08-10-2016, 10:01 AM
tberg's Avatar
Received 2,541 Likes on 1,412 Posts
What was the outcome of your dealer diagnosis? I have the adaptive dynamic warning after having a coolant tank replaced and wonder what I'm looking for.
Old 08-10-2016, 10:16 AM
2013XK's Avatar
The suspension shop blew out all four of my shocks. I had to replace the right rear strut to get my adaptive mode back. $400 lowering springs caused $5k in damage to my suspension. The worthless dealer, San Diego Jaguar, was stumped after a week and literally kicked my car out of the garage. I had to take it to another shop that specializes in modifying high end luxury cars and exotics. They figured it out in 5 seconds, replaced the strut and I have been good ever since.
I'm not sure what relation a coolant tank is to the dynamic mode but maybe you have a separate issue all together.
kj07xk (08-10-2016)
Old 08-10-2016, 10:49 PM
tberg's Avatar
I also replaced all 4 shocks about 2 weeks ago, but did not have the warning at that time. Will have to check all connections.
Old 10-17-2018, 07:06 AM
Sanibel0402's Avatar
I had a coolant hose replaced, drove home. Next day started up and the adaptive dynamic code came on. Did you ever find out the cause?
Old 10-17-2018, 08:35 AM
tberg's Avatar
Sanibel0402,
We must have found it because I don't have it any longer. I just can't remember what it was. When I'm at my mechanic later this week I'll see if he remembers.
Thanks.
Sanibel0402 (10-17-2018)
ionixxx
12-26-2015 08:12 PM
Lookout!
12-15-2015 04:45 PM
x type diesel
12-09-2015 05:40 PM
Grio
12-08-2015 09:20 AM
jamdmyers
12-08-2015 07:19 AM
Quick Reply: Adaptive Dynamic Mode Fault
