electrical gremlin
Old Jan 15, 2013 | 10:02 PM
2007 Rick's Avatar
Default electrical gremlin
Hello to all......
It's happened twice and I'm curious if anyone else has experienced this or has an answer. When I turn the car on the mileage/fuel gauge did not light up. Everything else was fine. Any thoughts? (2007 XK)
Old Jan 15, 2013 | 10:42 PM
CleverName's Avatar
Have you checked battery voltage yet?
Old Jan 16, 2013 | 09:37 AM
chakka's Avatar
Originally Posted by 2007 Rick
Hello to all......
Just posted this same observation recently. It seems like a voltage issue. Both times it happened, my car sat for a week in very cold conditions.
Now with daily driving it again, no issue's. Friend had the same happen with his 2007 XKR. Mine is an 09', but did sit on a lot for 5 months last year, so I may install a new battery this spring. But again, now that i'm driving it more regularly no issue's at all.
Old Jan 16, 2013 | 06:12 PM
2007 Rick's Avatar
Hello to all......
Thanks for the quick replys. Bat voltage is fine. Car was driven the previous day. It's been very cold here in NorCal -2 but so what. Last time it happened it was 75 out. Keeps the ideas/answers coming.
Old Jan 16, 2013 | 09:49 PM
TFlan's Avatar
The electronics in these gems seem to be extremely sensitive to battery voltage. I, along with a number of others here, have had issues with the touch screen periodically locking up and the culprit was battery voltage. The car starts fine. However, the voltage drops just enough to screw with the electronics. Am about to install my third battery in a year.
I'm not suggesting that battery voltage is the cause of your problem. I do agree that it's a good place to start.
Good luck!
Old Jan 16, 2013 | 10:04 PM
amcdonal86's Avatar
2007 Rick, did you measure the voltage, or did you surmise that it was fine because the car runs and drives fine?
Does anyone have any idea what it's supposed to measure?
Old Jan 16, 2013 | 10:25 PM
WhiteXKR's Avatar
A good indication of a marginal battery is less than 12.4 volts at the battery terminals, with the ignition off, after the car has not been running at least 8 hours.
bdboyle
Nov 6, 2015 02:07 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
magmedia
Sep 28, 2015 09:49 PM
