Sponsored by: DashLynx
Emergency steering rack issue
Old 07-07-2018, 12:20 PM
Ranchero50's Avatar
Reread the OP, surprised you didn't have the tow company swap the tire versus load it. Also with a flat rear I'm surprised they didn't drag the exhaust when he loaded it.
Queen and Country (07-07-2018)
Old 07-07-2018, 02:27 PM
chazaroo's Avatar
Here are photos of the driver and passenger side. Driver side straight. Passenger side quite bent.
ralphwg (07-07-2018)
Old 07-07-2018, 03:09 PM
Ranchero50's Avatar
Yeah, he hooked the J hook into the tie rod and not the lower A arm like he should have. I've done it myself but luckily it was on junk that was getting parted out. Hard to see where the hook ends up on a lower car with a big low nose like ours. I'd call some local indy's up and see if they would be interested in the repair. Should be the same tech as the S type and many Fords.
Old 07-07-2018, 03:18 PM
Cee Jay's Avatar
Received 5,153 Likes on 3,086 Posts
Nice Tires!
chazaroo (07-08-2018)
Old 07-07-2018, 03:54 PM
pwpacp's Avatar
Ventus V12 EVO 2 are great.
Old 07-07-2018, 04:53 PM
myexcursion's Avatar
Originally Posted by Queen and Country
You have to fail at a lot in life to become a tow truck driver in South Florida.
I saw them towing a XJ (from a dealership, so not a repo) where they could not figure out the emergency brake release, so they dragged it with tries screeching and the car put up a hell of a fight.
I always wondered how to tow the 07 if needed if car does not turn on — how do you get it in Neutral in order not to have to drag the car ??
Old 07-07-2018, 08:42 PM
Queen and Country's Avatar
Received 2,380 Likes on 1,607 Posts
Its a bit of a procedure, best to learn it before you need to do it. I believe your owners manual has a section on it.
  #28
Old 07-08-2018, 06:39 AM
IanXF's Avatar
older jag but same procedure
The following 2 users liked this post by IanXF:
chazaroo (07-08-2018), ralphwg (07-08-2018)
Old 07-08-2018, 08:42 AM
chazaroo's Avatar
Originally Posted by IanXF
https://youtu.be/Y_JWOyBoR9w older jag but same procedure
As I understand it, this is a different situation. In 2010, I am told, the tie rod is part of the steering rack and can't be removed. Am I not correct?
  #30
Old 07-08-2018, 09:17 AM
Ranchero50's Avatar
Should be a tow hook in spare goes in the cutout in the bumper ��
Nope, not on a roll back because with the winch on the deck centerline it'll pull the car off to the side of the deck as it comes up. Once the car is up you restrain the rear and then pull it a little further to lock it down. To the OP, take a look at your rear end to make sure they didn't tweak something else. The rear hook between the muffler and vanity cover is in a bad spot too. Easy to mess something up with th hook or miss it and grab something else that's fragile.
These cars suffer from the crappy European recovery standards.
  #31
Old 07-08-2018, 10:27 AM
IanXF's Avatar
Inner rod on 2010 XK
chazaroo (07-08-2018), Patrick Wong (07-11-2018)
  #32
Old 07-08-2018, 10:41 AM
chazaroo's Avatar
Wow, if that's the case, this isn't going to be too bad at all. Take the $2,900 steering rack off the table and this is pretty affordable.
  #33
Old 07-08-2018, 12:26 PM
Patrick Wong's Avatar
1. MSRP is $2,900 but you can buy the steering gear for $2,088 plus shipping at parts.com
2. Or you could buy a used steering gear from a salvage vehicle hit in the rear.
3. The Jaguar parts catalog does not seem to offer an inner tie rod as a separately replaceable part. Per the diagram below, you can buy the outer tie rod and the boot as separate parts.
  #34
Old 07-08-2018, 12:59 PM
Sean W's Avatar
Received 4,166 Likes on 2,335 Posts
see post 31
  #35
Old 07-08-2018, 01:59 PM
Ranchero50's Avatar
Wink
Originally Posted by Sean W
see post 31
Horse / Water...
The following 2 users liked this post by Ranchero50:
chazaroo (07-10-2018), Sean W (07-08-2018)
  #36
Old 07-08-2018, 02:48 PM
IanXF's Avatar
Why would you replace the whole part when a repair can be done just saying even an Indy fixing it would be far less than replacing the rack .
  #37
Old 07-08-2018, 03:32 PM
Certainly, if the inner tie rod can be replaced; and if the part in post 31 is correct, then no problem.
Notice there are two IF statements above.
However since the Jaguar parts catalog does not list that part, the OP will bear the risk in the event the inner tie rod cannot be replaced or the part number is incorrect.
$100 is a small price to pay to see whether those two IF statements are valid. If the part doesn’t work then the OP will have to pay for a replacement rack, but at least he will have tried, and this will add new knowledge to the group one way or the other.
  #38
Old 07-08-2018, 04:51 PM
IanXF's Avatar
True. it is simple enough to check if it’s removable or not . Guess if it was me I would just open the boot up and see rather than pulling the rack.i hope to give the OP just other options
  #39
Old 07-10-2018, 07:30 AM
chazaroo's Avatar
Dropped it off with Indy yesterday. I'll get it back Thursday or Friday. Fingers crossed but if there are people out there selling inner tie rods, I would assume there's a way to install them.
  #40
Old 07-11-2018, 03:04 PM
chazaroo's Avatar
The results are in! Indy just called me and the new inner tie rods have been installed. It goes for an alignment tomorrow and I'll have it back.
The following 3 users liked this post by chazaroo:
Cee Jay (07-11-2018), Patrick Wong (07-11-2018), Ranchero50 (07-11-2018)
Quick Reply: Emergency steering rack issue
