Fault Codes
Evening folks
Got 2 weird fault codes appear on my XKR P0610 and P0630 Car isn't affected, drives fine, starts fine, changes gear fine. Tried clearing the codes, but they reappeared. I did have the battery off while fitting something, and it was after I are attached the connectors these codes appeared. Any help would be much appreciated |
Originally Posted by pauledddy
(Post 2080962)
Evening folks
Originally Posted by jagtoes
(Post 2081019)
The first question is what were you doing or fixing that you needed to remove the battery cables. Were you doing any electrical work or programming anything. I would be concerned with the P0630 as this one does not recognize the vin number of your car and could potentially prevent your car from starting.
Anyone have any input on these codes?
I've bought an SDD, I know about the constant battery voltage needed as well. So will update further when I have my car back from the paint shop |
https://cimg2.ibsrv.net/gimg/www.jag...464b5eb057.jpg
https://cimg1.ibsrv.net/gimg/www.jag...cef946ebb7.jpg Someone did, or tried to, re-map the car in the past? Flash a different engine tune to the car? In any case you will be rolling the dice trying to re-flash the PCM, CJB or RJB with an eBay or British Diagnostics crap SDD. Personally, if the car starts, runs and drives fine, no errors on the dash, then I'd let sleeping dogs lie... |
Originally Posted by Cambo
(Post 2081612)
....... if the car starts, runs and drives fine, no errors on the dash, then I'd let sleeping dogs lie...
If I don't have a MIL, an error message or a bad feeling about how the car is running, I leave my SDD alone. Graham |
I don't know if it's been mapped in the passed. The EML is illuminated and won't clear. But as stated it drives fine, but the light is bothering me!
How do i go about this issue?? |
Possible to contact the previous owner, to see if a mapping was done?
So, I've just disconnected the battery for a good 10-20 minutes and the code has disappeared.. haven't driven it yet si not sure if itll come back!
