FM1 is gone
Just disappeared. Well, I can see FM1 and all of the presets as I cycle thru the sources (via touch panel or steering wheel) but the stations remain on AM and when I select an FM1 preset, it switches the AM preset. AM works normally. FM2 works normally.
I found a thread that said to remove fuse 21 and 25 in the rear panel. I did that, left them out for about a minute, did not fix the problem. Any other things to try? thanks! |
