Front left headlight intermittently failing
Hi all
Anybody here is familiar with the following headlight issue? Seldomly - like once a week - the low beam headlight on the driver side does not work. All other lights do work. And interestingly there is NO FAILURE MESSAGE in the dashboard informing about a failed bulb or similar. Therefore it is only in absolute darkness or when the headlights mirror in the car in front when I notice that the left headlight is off. When I then cycle the lights on/off, the left headlight is usually back to work. Any ideas?? BR ter |
Sounds like time for a new bulb.
Originally Posted by 110reef
(Post 2052665)
br ter ps: just watching Jay Leno driving around in a white E Type coupe on YouTube. Great watch... |
Try turning on and off when problem occurs, if it comes back on, its the ballast (driver for hid)
Originally Posted by Queen and Country
(Post 2052752)
br ter |
HIDs need real high voltage. What's happening is that the capacitor is only partially charging on the first go around, not enough for a power on. Over time the capacitor will only get worse. Caps have a lifespan.
But in this case it seems to be isolated to a less than perfect cap. Those damn Brits with their fat greasy fingers from the chips, covered in circuit destroying salt and vinegar and only newsprint to wipe with. |
(Post 2052858)
