Front ride height xkr 4.2
Old Jul 22, 2023 | 02:27 AM
steve_k_xk's Avatar
Default Front ride height xkr 4.2
Ive lost my measurements would someone be able to measure the ground to arch going through the middle of the rim .... looking to see the ride height of xkr 4.2 on standard 20s
Should land somewhere in 705-715mm roughly
Old Jul 22, 2023 | 10:19 AM
kj07xk's Avatar
Probably not exactly the info you’re looking for, but on my 4.2L XK, originally equipped with 19” wheels, but now riding on 20’s, the ground to wheel arch is 27.75”, and the center of the wheel cap to arch is 15”.
The second measurement is probably more useful, as the ground height will be affected by type of tire and inflation.
Old Jul 22, 2023 | 06:14 PM
steve_k_xk's Avatar
Exactly same measurements with mine and I have firmer springs in this ....either the new insolaters in mine brought it up or the older isolators in your brought it down or a little combination of both haha
nevertheless thank you !
Old Jul 22, 2023 | 07:11 PM
Cee Jay's Avatar
My kid's 2007 XKR measures as 27-13/16" rear and 28-1/16 front. Course half the engine is in the boot, so that is maybe a sixteenth or so. I also have not checked the tire pressure.
Old Jul 22, 2023 | 07:15 PM
Sean W's Avatar
Ride Height Factory Specs here Steve
FRONT REAR
Naturally aspirated (NA) 396 mm ± 15 mm 396 mm ± 15 mm
Supercharged (SC) without dynamics pack 394 mm ± 15 mm 393 mm ± 15 mm
Supercharged (SC) with dynamics pack 384 mm ± 15 mm 379 mm ± 15 mm
  • All the above figures are measured at "kerb" height -all fluids at full and a full fuel tank.
  • Tires must be inflated to normal pressure
  • Rear thrust angle = (LH toe - RH toe) ÷ 2
  • Ride height is measured from the centre of the wheel to the apex of the wheel arch,
    through the wheel centre line.
Old Jul 22, 2023 | 07:29 PM
jahummer's Avatar
The difference in height between new parts and aged parts can be quite significant as suspension sags over time.
Old Jul 22, 2023 | 08:01 PM
steve_k_xk's Avatar
What's your xkr currently sitting at out of interest with that bc
Old Jul 22, 2023 | 08:16 PM
steve_k_xk's Avatar
My rears were 690mm with the eibach springs , placed some spacers in and brought height back up to 705mm
Old Jul 22, 2023 | 09:43 PM
jahummer's Avatar
I'll check. Mine's corner balanced as well which will affect heights.
Old Jul 24, 2023 | 03:40 PM
guy's Avatar
guy
From the horses' mouth
File Type: pdf
Old Jul 24, 2023 | 06:10 PM
steve_k_xk's Avatar
Exactly what I was after and thank you as well Sean as I saw you posted this previously
htrdlncn
Apr 18, 2023 02:54 AM
bt_bob1
Feb 19, 2022 11:32 AM
u102768
Feb 5, 2021 05:57 AM
User 070620
May 6, 2019 05:22 AM
