Fuel filling problem,pump cut out,very slow fill
Old Jul 26, 2018 | 05:45 AM
Jag00007's Avatar
Default Fuel filling problem,pump cut out,very slow fill
2014/XKR X150/19,000km/5ltr. While filling fuel, petrol pump cuts out when ever the flow is above a very low flow rate which leads to an extremely slow and tedious refueling process. This must be a problem experienced by other XKR X150 owners.
I would appreciate any assistance and suggestions.
Old Jul 26, 2018 | 08:40 AM
spanky145's Avatar
This problem has been discussed many times and I have experienced it with my 2012 XF and also my 2015 XF which was bought new.
For my problem with my 2015 car, the solution was found by replacing the fuel filler neck with a modified version that Jaguar had put out. This was done at a Jaguar dealership and while the car was still under warranty. It took the dealer about an hour and a half to change my filler neck to the revised one and I have not had a problem with filling up the car with gas since this was done. The work was done about 1 1/2 years ago and the problem has not surfaced again since the new designed fuel filler neck was installed..I wonder if there is a revised and new designed fuel filler neck for your model which may very well correct your problem.
I would discuss this with dealer. Good luck.
Old Jul 26, 2018 | 02:07 PM
Originally Posted by Jag00007
2014/XKR X150/19,000km/5ltr. While filling fuel, petrol pump cuts out when ever the flow is above a very low flow rate which leads to an extremely slow and tedious refueling process. This must be a problem experienced by other XKR X150 owners......
Welcome to the forum Jag00007,
I've moved your question from General Tech Help to XK/XKR forum. This is the place to post technical questions about your model.
Old Jul 26, 2018 | 05:18 PM
Cee Jay's Avatar
While it MAY be a filler neck problem, most slow-fills are caused by the Vapor Cannister, or "Evap" cannister. The carbon filled container hooked to the vent tube of the fuel tank. It clogs and prevents air from escaping during a fill, which over-pressures the tank and causes the pump valve to trip off.
Old Jul 26, 2018 | 07:20 PM
kj07xk's Avatar
Yep, my 2007 has been poky at the pump since I got it almost 4 years ago, just assumed it was a British thing.
Old Jul 26, 2018 | 07:42 PM
Jag00007's Avatar
Hello Graham,
Thank you for your assistance, I am still feeling my way into Jaguar Forums.
I have had some extremely helpful replies already.
I am so pleased I have joined with Jaguar Forums.
Best regards,
Chrris
Old Jul 26, 2018 | 08:11 PM
Ranchero50's Avatar
Also to add from what I've read, it's a side effect of overfilling the tank. Fuel gets up in the canister and turns the media into mush. I've needed to train myself into just going to the next 25 cents when filling after it clicks off the first time.
Old Jul 27, 2018 | 03:49 AM
Originally Posted by Cee Jay
While it MAY be a filler neck problem, most slow-fills are caused by the Vapor Cannister, or "Evap" cannister. The carbon filled container hooked to the vent tube of the fuel tank......
Not if your vehicle is European specification - only USA, Canada and Mexico specifications have the filler pipe with "Evap". Here is the filler pipe on my 2014:
It's a plain pipe and the only restriction is the splashback flap (this photo was taken as I replaced the filler bowl):
I've never had a fill problem with either my 2007 or 2014 XK's and I've driven them across England, France and Spain so have used a lot of different service stations.
However, there was a problem a few years back with Jaguars at many UK service stations. The fuel delivery rate was too high, fuel couldn't pass through to the tank quickly enough and soon built up in the filler tube until it triggered the pump cut off. The solution at the time was not to squeeze the pump trigger fully open and rotate the delivery nozzle through 90 degrees.
Two things appear to have happened here - trigger locks are no longer fitted (so you can't put the pump on then walk away and leave it filling - have to hold the trigger on) and flow rates have been reduced. I think this was most likely done because the money dial was rotating so fast it became a blur! It costs 85 UKP / 111 USD / 150 AUD to fill my XK.
Old Jul 27, 2018 | 12:03 PM
Cee Jay's Avatar
Originally Posted by GGG
Not if your vehicle is European specification - only USA, Canada and Mexico specifications have the filler pipe with "Evap".....................
Since I don't know, I will ask;
If Euro-spec cars don't have an Evap on the tank vent, there then should be a vent WITHOUT an evap canister. The air that is already INSIDE the tank needs to be dissipated whenever the tank is filled, and the filler neck is full of liquid when being filled, so then WHERE does the displaced air go????????
I really don't think that European spec tanks would have a direct-to-atmosphere vent line, that'd be dangerous.
Whichever, wherever, however, there needs to be a vent on the tank. That's where the problem may lie.
Old Jul 27, 2018 | 12:17 PM
Cee Jay's Avatar
Of course, I never said the Evap was on the Filler Neck.....
I did a search, but of course I only have the North America WM... US doesn't have it on the filler neck either.
Old Jul 27, 2018 | 12:23 PM
YES - there has to be a vent but I haven't got a photo which shows anything relevant. My main concern at the time was replacing the filler bowl.
Here's a comparison of the two fillers from JEPC. European pattern on the left and USA pattern on the right:
The fuel tank parts listing has a number of vent pipes so that could be the route.
Old Jul 31, 2018 | 06:20 AM
Jag00007's Avatar
Thank you for your information. I am booked in to the Jaguar dealer next week.
Old Jul 31, 2018 | 06:22 AM
Jag00007's Avatar
Thank you for you information, I have booked the XKR into the dealer next week.
Old Feb 12, 2025 | 10:26 AM
bocatrip's Avatar
Sorry for bringing up an old thread.....Since I've been using my low mileage 2010 XK (17,000 miles) I've experienced this slow fill up syndrome and it's quite annoying. Is there any other fix that any owners have applied to resolve or help this slow fill up? How about allowing the fuel to get lower (1/4 tank) before fill ups? I usually fill up around 1/2 tank. Thanks all.
xtypelux
Jan 14, 2018 10:54 AM
oxo
Aug 14, 2017 06:39 AM
larry g
May 24, 2017 08:01 AM
tony skinner
Jan 15, 2017 03:17 PM
Punch Ford
Nov 30, 2016 03:52 PM
