Gearbox
Hello all?
Does anyone know who the manufacturer is of the gearbox from mine xk 5.0 out of 2010? Thx in advance for the effort of the reactioen. Grtz Ben |
Thought all X150 transmissions were made by ZF. |
ZF; 4.2 cars should have the 6-speed 6HP26 with a gear stick, while 5.0 cars should have the
EDIT: Misunderstanding, I probably recalled seeing a thread discussing whether an early 5.0 might have the J-gate instead of the rotary selector... |
Originally Posted by Aonsaithya
(Post 2037321)
ZF; 4.2 cars should have the 6-speed 6HP26 with a gear stick, while 5.0 cars should have the 8-speed 6HP28 with the rotary gear selector.
I do vaguely recall seeing some thread discussing whether some early 5.0 might've had the 6-speed, though...? TiA |
My 2012 XKR list a 6 speed transmission on the window speaker . I also know based on the numbers when the paddles are used and by the number of shifts in normal drive mode. I do believe it is a different transmission then the 4.2 cars.
Originally Posted by Someb
(Post 2037324)
I have for sure an six speed gearbox in my jaguar xk 5.0 convertible; so what brand and type?
TiA To verify, you can create an account for TOPIx and look up your car specs with your VIN (or you can post the VIN here and someone may do it for you). This information should include the gearbox; it states "6-Speed Automatic 6HP26" for mine. |
(Post 2037423)
ZF is the brand as I said, and whether it's 6HP26 or 6HP28 depends on the number of gears you have.
(Post 2037423)
Originally Posted by u102768
(Post 2037434)
The 6 in 6HP is the number of gears so both 4.2 and 5.0 XK's have 6 speed gear boxes. The 28 is just the evolution.
(Post 2037430)
Topix is not for customers I believe :(
(Post 2037462)
Looks like you're right, my bad! I wonder where I picked the 8 speed up from...
(Post 2037462)
Course, you could always just look at the VIN decoder.
https://www.jaguarforums.com/forum/vindecoder.php |
