Heated Windshield?
I was just searching the forum and read a post saying that some car's have heated windshields and some don't. Does the heated offer a big advantage? Do the 07-09 MY offer this and if so how do you tell? Thanks!
If it's heated, you'll have a dedicated button for next to the rear window heater button. If not, I think you just have a large rear window heater button, like the defroster button on the right.
https://cimg6.ibsrv.net/gimg/www.jag...6d33e55e83.jpg I have an interior heater that I run for 2 hours before starting the car, so I practically never have any ice on the windscreen anyway. However, when ambient temperature is freezing, I turn it on before I use wash the windscreen. Likewise, in some very specific weather (like supercooled rain), it's useful. The downside is higher cost on replacement and the thin wire grid within the glass, which some apparently find annoying/distracting. |
Thank you! That's why I was asking, I just bought my 08 XK from out of state and haven't even received my state plates yet and have gotten a tiny crack/chip (only mm's long). If it does start to grow and replacement is necessary I want to know which I have.
Originally Posted by Kongo1
(Post 2034857)
The heating elements rapidly clear fogging on the inside and are also effective for ice or frost on the outside. Glass shops merely take your VIN to obtain all the information necessary for replacement - this gives them a list of every feature on your specific car so you will not, for example, get a unheated glass if your car was originally fitted with a heated screen. There is no guesswork involved. But if you do get a replacement make sure that you ask for original Jaguar glass. There are sometimes fitting issues with aftermarket glass. |
Mine came with heated windscreen and I have never used it yet. Also they are pretty visible to me while driving.
My 2007 XK did not have a heated windscreen - my 2014 XK does have one as part of the standard Signature and Dynamic R specifications.
Although it can be switched on manually, it comes on automatically when the engine is started at 5 deg C / 41 deg F or below. There is also a timer in the circuit which switches it off after twenty minutes. https://cimg5.ibsrv.net/gimg/www.jag...a4a4fa046d.jpg Graham |
If it's a heated windshield, you'll see the heating elements in the glass. Just like the rear windshield, but they very thin and super close together. It's a must have feature for me. Even the one time the windshield is frosted it's worth it. Our Range Rover and XE came with this option. I would option this on any car if available (locale dependent). Some find the lines annoying, but I don't.
Originally Posted by sov211
(Post 2034863)
I read a thread that talked about the OEM windshield being exceptionally "soft" or defective. If this is the case would you still opt for an OEM or is this one instance where aftermarket might be better?? I did read Gregory's comment about fit issues with after market and I would think a bad fit is a bigger problem than a softer glass.
My 2008 windshield was replaced with a heated aftermarket
All looks good |
(Post 2035387)
Just an opinion... Vince |
Originally Posted by CleverName
(Post 2035651)
Good question. From my experience (replaced the windshield in my XK, as well as my XKR). My XK glass is OEM, while my XKR glass is aftermarket. To date, I believe my XKR windshield is showing far more sandblasting effect on it than the Jaguar version. To be fair, I drive the XKR more, but I've had the XK 3 years longer.
Just an opinion... Vince https://www.pce-instruments.com/us/m...kat&_listpos=7 |
(Post 2035387)
Still a nice inexpensive tool for A/B comparisons if someone had the need. I've used the Rockwell testers in aviation maintenance, but never needed it outside that. |
Interesting.
I can see wires in my windshield but I do not have a separate button for electric heating. |
Originally Posted by flyc2c
(Post 2036738)
Interesting.
(Post 2036738)
Interesting.
I'm not distracted by the heating element and it is extremely difficult to photograph the wires. Here's the view from my 2005 XK8 as an example:
https://cimg6.ibsrv.net/gimg/www.jag...773384ae08.jpg Graham |
Yep I can see them and looks pretty much the same as mine.
Originally Posted by Aonsaithya
(Post 2036757)
Have you checked the equipment listing of your car on TOPIx?
