Help changing daytime running light
Anyone know how the heck to change the front upper daytime running lamp? It’s a T10 bulb, I removed the front headlight assembly and still couldn’t replace the bulb.
https://cimg9.ibsrv.net/gimg/www.jag...338846aa2.jpeg |
Not sure what your having an issue with? Once you pull the headlight assembly, you need to open up the the side domed cap to gain access to bulbs. Depending on what bulb your replacing you may need to remove other bulbs to get to the most inner bulb... Here is a link to when I did my led conversion, read through it an see if it helps you...
https://www.jaguarforums.com/forum/x...pgrade-195058/ |
Originally Posted by TexasTraveler
(Post 2064712)
I changed mine to LED with no problem.
Can't you reach in or is it like stuck when you try to remove it? |
I think I know the problem. It has a led bulb in it now that is big preventing access.
(Post 2064922)
So, up inside where the green arrow is then? Dang, some pictures sure would help...
https://cimg4.ibsrv.net/gimg/www.jag...c388ba22a1.jpg |
Let's clarify something here. The OP is not referring to the DRL bulb, but to the cornering light bulb in the Active light system (meaning the optional swivelling main light system). This cornering light only illuminates when the wheels are turned, and the other lights are on (the turn signal might also be involved in activating the cornering lamp...not certain, though), so this makes me wonder if there is in fact any problem with the bulb...or have I got this completely wrong and misunderstood? (Not at all impossible...still working on my first cup of coffee...).
Yeah, this one.......... but I haven't had my housings out for a few years so I don't remember what the backside is like...
https://cimg8.ibsrv.net/gimg/www.jag...2df8a33411.jpg |
[QUOTE=Cee Jay;2065831]Yeah, this one.......... but I haven't had my housings out for a few years so I don't remember what the backside is like...
https://cimg8.ibsrv.net/gimg/www.jag...2df8a33411.jpg[/ QUOTE] Bingo! that's the one |
Originally Posted by sov211
(Post 2065782)
Originally Posted by badicedog
(Post 2065997)
Incorrect. I've changed the cornering light without problem. It's the little bugger next to it.
according to the handbook the-- little bugger next to it-- is the side lamp and it is accessed through the the twist of large large domed cap
Originally Posted by plc
(Post 2066137)
Success at last! Had to use a set of medical forceps to get a firm hold of the bulb receptacle. What a PITA. thanks for all your advice/help.
