Help Locate A/C low side charge port 2009 XKR - RESOLVED
Old Jul 2, 2018 | 05:18 PM
AugustinAustin's Avatar
Default Help Locate A/C low side charge port 2009 XKR - RESOLVED
Help in locating A/C low side charge port 2009 XKR- have looked on the web endlessly. High side I found quickly up top but I cannot find low....not in drivers wheel well as so many indicate, your help greatly appreciated.
Last edited by GGG; Jul 4, 2018 at 01:17 PM. Reason: Add "RESOLVED" to thread title
Old Jul 2, 2018 | 05:41 PM
NBCat's Avatar
This question should be posted in the X150 forum if the vehicle is a 2009 MY XKR.
Refer to page fifty and onward of the Electrical Guide:
https://www.dropbox.com/s/0872e68rft...rical.pdf?dl=0
Old Jul 2, 2018 | 05:58 PM
I've moved to the appropriate forum.
Old Jul 2, 2018 | 05:59 PM
Thank you gentlemen
Old Jul 3, 2018 | 05:20 AM
Did you find it?
Item 9 = High pressure servicing connection
Item 10 = Low pressure servicing connection
Old Jul 3, 2018 | 07:15 AM
Ranchero50's Avatar
Ditto. For the low pressure you remove the left side air intake. High side is next to the PS reservoir.
Old Jul 3, 2018 | 07:54 AM
Yes I did. Have to remove drivers side intake tube to connect gauges, reinstall to start engine, charge and repeat the intake dance. Lovely place for the jag engineers to put it but all ended well at 42 degrees with a 88 ambient. I posted some pics to make it easier for the next searcher. Thank you gentlemen for your help
Low side port at screw drivers tip
reinstall intake to charge
low side port location
for central Texas this is like 10 below
JimC64
Sep 22, 2025 02:52 PM
SteveM
Motorsports
103
Oct 19, 2024 02:58 PM
08292
Oct 30, 2023 09:05 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
sjuraud
Aug 28, 2010 02:11 PM
