How do you use your key fob
Having seen a few posts on key fobs it struck me that some use theirs more then others. As a for instance I really don't use mine other then putting it in my pocket when I leave the house. It stays there during my day out . I lock the doors by pushing the button and if I need to get into the boot I either hit the button in the car or press the button on the boot lid. Other then that I can't remember if I had pressed any of the buttons on the fob. So if someone ever invented a credit card size fob that I could put in my wallet I wouldn't have a need to carry one. By the way I find the Jaguar fob much lighter then my Lexus or Chevy truck fob. Just sayin
Like you JT, I don't use the fob at all except to turn off the alarm when I accidentally set it off.
I'm like you. I NEVER use the buttons on my fob. It's in my pocket, but that's it.
Almost always, 3 taps on the unlock button as I approach the car, to drop the top with theJagWrangler's remote top control... it's just so cool. :icon_eddie:
KJ, too cool! It is on my radar for mod too.
I just keep it in my pocket or bag. However, if I've parked in a tight spot, I may use the fob to open the windows; pillarless doors with the windows down make for an easy entry.
I know one can close the windows with the fob or by holding down the locking button on the door handle, but I wonder if it's possible to open the windows without touching the fob? Oh, and one time I was taking a photo of my car, and turned on the headlights remotely to see what it looks like. |
Originally Posted by jagtoes
(Post 1861771)
Windows in the summer but otherwise, just in my pocket.
Originally Posted by kj07xk
(Post 1861778)
I use both the fob and keyless entry. Keyless first, but sometimes doesn't work.
Three taps on the Lock Button on the Door Handle will also raise and lower the top, using Steve's stuff.
Originally Posted by Cee Jay
(Post 1861862)
Had to use the Lock/Unlock buttons on my previous 2007 XK but just leave the fob in my pocket with my 2014 keyless entry vehicle.
Graham |
(Post 1861873)
So true, but having the top down and ready to go by the time you get to the car, is special. |
(Post 1861997)
I do that in parking lots and other places when I'm out already. Pulling out of the garage, I first start 'er up THEN lower the top. That way I occupy some of the time that I wait for the idle to die down before I leave.
I gotta say after doing a little test of lowering the top without the engine running it's something I'll not be doing. You can watch the voltage drop/drain as it lowers. That would suggest to me that coupled with the start process your battery is going to take a pretty hard hit. I start the car and while the idle is up (open loop) I lower the top. Just my thoughts .
We have just come out of summer here so if I am coming home from work I unlock the car as I approach then press the button again to open the windows then put my suit jacket and anything else I am carrying on the passenger seat through the open window then get in and head for home.
Is holding unlock to lower windows a vert thing? Tried it on my coupe and nothing... |
Mine do, but missed opportunity; they don't go back UP by holding LOCK.
The rear quarter windows on the coupe are fixed, and do not open or close. There is no regulator mechanism or motor to move those windows.
From the factory, the convertible's rear quarter windows are synched with the top. They go down when the top is lowered and go up when it is raised. When the top is down, you can raise and lower the front side windows, but not the rear quarter windows. They stay down when the top is down and stay up when the top is up. WhiteXKR's remote top kit with the optional rear side window controller makes it possible to lower and raise the convertible's rear quarter windows when the top is up or down, separate from the front side windows. With his kit, you can lower all 4 windows with the top up, or raise all 4 windows with the top down, which is not possible straight from the factory. The cabin is much calmer with the top down and all 4 windows up and a rear wind blocker. Both rear quarter windows move up or down at the same time, but the front side windows operate independently. All 4 windows can be controlled by the window switches or key fob, by using the right sequence of switch/button pulls and pushes. |
