I need a seat module, are there discount part suppliers?
Old May 31, 2020 | 09:28 AM
jagophile's Avatar
Default I need a seat module, are there discount part suppliers?
I just joined having purchased my 2004 XK8 a few days ago. I need a passenger seat module (controller) as this one is completely missing. Is this a used item, a dealer item, or are there discounted parts vendors? I searched a bit and offer my apologies if the answer is already here, but I failed to find it. How do you good people find the right part numbers, is there a master parts catalog somewhere? I like to do my own work but need a good source of Jag parts. Thanks in advance for any insights or new owner advice you may have.
Old May 31, 2020 | 10:04 AM
Cee Jay's Avatar
Oopsies, you got into the wrong forum. You're looking for the XK8-XKR (X100) forum for the 1997-2006 models. This is the X150 forum.
Old May 31, 2020 | 10:48 AM
MarkyUK's Avatar
Several on the little known 'Bay of E' if you search It helps if you search the part no, the actual number will be the same right or left, just the last two digits may be different.
Old Jun 1, 2020 | 08:25 AM
jagophile's Avatar
Thank you both for the reply. My apologies for posting to the wrong spot.
Old Jun 1, 2020 | 09:05 AM
jagophile's Avatar
thanks for this, not sure which is the part number. Here is a "blind" shot under the driver seat module. Are these the numbers I should search? So far no car parts on Fleabay under any of these digits... Should I pull the module and look for a different set of numbers somewhere on the case?
Old Jun 1, 2020 | 11:16 AM
Cee Jay's Avatar
Does this help? Ebay has a lot of them. Evidently they cross models so there is a larger supply.
XK8 Seat Control Modules on eBay
Old Jun 2, 2020 | 12:38 PM
jagophile's Avatar
Yes that helps a lot. I pulled the driver side and find LJE2160AB is there. Most important none of the 2004 modules have the proper connections, it appears my seats need a 2003 controller with the 10 pin and 16 pin square connectors. However, there is no LJE2160 on ebay, will a LNC2160AD work for me? I suspect left and right are different. I am still a newbie to Jaguar jargon and do not know what these variants in part number mean.
Lafe
Nov 25, 2024 03:03 AM
bobe
Canada
May 22, 2014 04:39 PM
David Lawson
Dec 25, 2013 06:30 PM
BriteRed01XKR
Aug 31, 2011 05:44 AM
JagXK82001
May 18, 2011 04:02 AM
