Leather on dash 'pulling'
Old 05-21-2017, 10:23 PM
RedRider48's Avatar
When completed, refer them to the states......
  #262
Old 05-22-2017, 01:06 PM
Sean W's Avatar
Received 4,164 Likes on 2,334 Posts
Originally Posted by Ozmag
Just got a call from Jaguar Australia Customer Service, they have assigned a case worker so interesting to see what happens!
Hmmm, here in the States, that just means your going to therapy.
  #263
Old 05-22-2017, 05:02 PM
Ozmag's Avatar
I don't have high hopes in fairness but we will see. They are getting a Dealer to call me to review, despite I work next door to Jag Australia Head Office
  #264
Old 05-23-2017, 10:13 AM
JackJohn's Avatar
Good Luck Ozmag, I always hate dealing with middlemen, something always gets lost in the translation.
Ozmag (05-24-2017)
  #265
Old 05-23-2017, 10:27 AM
amcdonal86's Avatar
Has anyone had the repair done in the Washington DC area (<100 miles?) successfully and how much did you pay??
makecopies (05-26-2017)
  #266
Old 05-23-2017, 01:36 PM
tberg's Avatar
Received 2,540 Likes on 1,411 Posts
Please see my numerous posts on this thread. If you can have the dash pulled by a mechanic, any upholsterer can repair it within a couple of hours for next to nothing. You don't need a specialist. The dash removal and re-installation will cost you a couple of hundred dollars or more, but the repair should not be more than a hundred dollars if that much. It's been more than 3 years, and mine is still perfect.
Ozmag (05-24-2017)
  #267
Old 05-24-2017, 07:56 PM
Ozmag's Avatar
Dealer called me - I have an appointment on Tuesday morning for them to review, photograph and report to Jaguar.......
Savitt1 (01-27-2021)
  #268
Old 05-24-2017, 09:58 PM
amcdonal86's Avatar
can the car be moved under it's own power without the dash?
Also, I have heard of big problems with the demister vents crumbling, and these are not separately available. Did you have any issues?
  #269
Old 05-25-2017, 11:36 PM
tberg's Avatar
I doubt you would want to drive without a dash, but a well planned day could have the dash removed, repaired, and replaced within probably 8 hours. And it is possible that the repairs could be made with the removal of the windshield and an upholsterer being able to get a long nosed air stapler in at the front of the dash and around the center speaker (since the glass would not be in the way). I was having body modifications done at the time and I wanted to do the dash repair simultaneously. I hadn't known in advance how straightforward the repair would be). As for the defroster vents, they will most likely crack as mine did in several places. We saved all of the pieces and glued them back together. They are not readily apparent unless you are looking for them from outside the front. Tomorrow, in the light, I can take some pictures and post. My repair is over three years old, and you don't really notice the repairs, and the dash still looks perfect.
  #270
Old 05-26-2017, 09:42 AM
makecopies's Avatar
I'm wondering this too
  #271
Old 05-26-2017, 01:57 PM
ajzride's Avatar
I don't see how the car could be moved without the dash, too mush stuff disconnected, it throws tons of errors. I supposed you could try to hook all the infotainment and console devices back up, but that would be a major pain, you'd have to duct tape the stuff in place.
  #272
Old 06-01-2017, 04:19 PM
jerome41441's Avatar
Gents, I live in Central Texas and God knows the sun is hot here. My dash, even with my religiously using a sun screen, started to puff up, make waves and eventually pull away. I went to my Jaguar Dealer and service center in San Antonio, Texas because the one in Austin, Texas thinks that Jaguar customers are a bother, they like Land and Range Rover customers better. They looked at my problem and told me that the entire dash had to be replaced because once the leather stretches that way, it also warps the backer board of the dash. Me being me, I thought that was a crock of BS, for our British readers that would be Cow Manure or Excrement. I remembered that in a conversation I had with my Mercedes mechanic that if you take a hair dryer and a damp cloth and a plastic straight edge, that you can get all the imperfections out of leather, oh plus a little elbow grease. So i tried it, and I was able to streach the leather back out, all the way to the edge and beyond. The problem I had there was that I didnt have a tool thin enough to tuck the leathger back down the edges without damaging the leather. I have since found a tool, a ginocoligist spatula, just know I have friends in interesting places lol. I was able to tuck the leather back in but not perminately, because to do that you have to take the dash apart and reconnect the leather to clips. If you try and glue the leather down, in hot areas like Texas it will harden up, the glue, and discolor your leather and it will be very noticeable. The dealer wanted to charge me $3600 to replace the dash. A body shop or interior shop will redo it for about $500, just ask them to put a layer of padding between the leather and the backer board. Hope this helps guys and ladies
The following 3 users liked this post by jerome41441:
Ozmag (06-01-2017), ralphwg (06-01-2017), Savitt1 (01-27-2021)
  #273
Old 06-01-2017, 11:24 PM
RedRider48's Avatar
good for you!
  #274
Old 06-02-2017, 01:23 AM
RobB's Avatar
Angry
Thanks for this. My 2010 has just started to bubble. As one local specialist has declined to even attempt to remove the dashboard, and another has told me the replacement dash alone is $6k over here (plus removal and refit!), I'll wait until the bubble gets to the edge and then look to repair it..
  #275
Old 06-02-2017, 03:28 AM
u102768's Avatar
Received 1,484 Likes on 907 Posts
Originally Posted by RobB
... and another has told me the replacement dash alone is $6k over here (plus removal and refit!)
I don't know if it is suitable for your car or what it would cost to ship but I saw this on EBAY earlier in the week:
Jaguar XK XKR X150 Dashboard Dash No Air Bag - Never Fitted | eBay
  #276
Old 06-02-2017, 03:29 PM
RobB's Avatar
Thank you for the link. For the price, it seems remarkable, although the phrase 'may have some storage marks' is odd. I'll see what my things off it..
  #277
Old 06-02-2017, 04:40 PM
myexcursion's Avatar
Anyone ever try using this on top of the dash ? Maybe it's a good preventative measure for those that still haven't had it pull back, or even to cover the existing one ?? I was driving in traffic next a Ferrari 360 today and he had a mat on his dash too - lol. I've seen they come in suede and carpet. never know ... might give it a try.
Dash Cover - Jaguar XK Series 2007-2015
or
Dashmat Dashboard Covers | Dash Covers for Cars | PolyCarpet, Velour, Suede, Molded
  #278
Old 06-02-2017, 07:15 PM
tberg's Avatar
RobB (and anyone else who thinks jerome's solution will work),
Unfortunately jerome's solution which is to restretch the leather, tuck it back to the lip of the dash in front of the windshield with a spatula of sorts, will not be a permanent, nor even a temporary solution to this problem. Through the hundreds of posts on this subject on both the XK/XKR and XF forums, outside of getting a dealership to replace the dash under warranty, apparently no one besides me has successfully repaired their dashes. There is NO SCENARIO, NONE! that will provide a permanent solution to this problem without anchoring the leather to the frame via staples. PERIOD! There are no "clips" to which the leather was originally attached, there were no magic fasteners, there was just glue. Jaguar did not even provide enough of an overlap of the leather to wrap around the underside of the dash where it might have helped to keep the leather from creeping up. The pictures on my early posts on this subject show the lack of any fasteners. I was fortunate to have a mechanic/body shop with whom I do a lot of business, take the dash out for me, so that I could repair it properly. The only other possibility without dash removal is windshield removal. I believe that with the glass removed, a long nosed air stapler can reach the lip at the back of the dash as well as around the center speaker. With glass out, the leather should be able to be pulled away from the foam, restretched, regued, and finally anchored/stapled to the frame. The removal of the windshield shouldn't be more than a couple of hundred dollars including re-installation as I have had it done on my other XKR by Safelite, and it was $225 including a new windshield. Everyone seems to have a theory about how to come up with an easy solution to this very common problem, but no one has actually done it and had a successful outcome besides me. As I've previously stated, I repaired mine more than 3 years ago, and there has been no change in its appearance since then. My car has never spent a night in a garage (during my ownership), is subject to temperatures in the San Fernando Valley that can reach (as it did one day this past summer) 120F, and which are typically between 90-110F from June through the end of October.
I am going to walk out to my car right now, take some photos, and post back in a few minutes to prove the point.
The solution is not rocket science but still has to be done correctly to work.
Ozmag (06-02-2017)
  #279
Old 06-02-2017, 07:39 PM
tberg's Avatar
Okay, below are some closeups of my dash. It was too sunny for the pictures from outside the windshield to turn out, so these will have to do for now. I wanted to show it from the outside, because as previously posted, so that the staples would not show to the outside of the front of the car, I glued a half inch black leather strip that matched the dash perfectly to the front lip. I will take those photos another time. If you look at the photos of my dash, you will see that the molded areas that slope down from the sides of the center speaker are perfectly tight (previously I had the typical air pockets), the area surrounding the center speaker is tight and flat, and the cover over the passenger airbag (which on my car was not attached at all, it flapped around like a flag in the breeze) is perfectly fitted. All of this accomplished with a little bit of adhesive, and a couple of dozen staples, and that's it. And there is no other way.
Attached Thumbnails Leather on dash 'pulling'-dscf8371.jpg   Leather on dash 'pulling'-dscf8372.jpg   Leather on dash 'pulling'-dscf8373.jpg   Leather on dash 'pulling'-dscf8370.jpg   Leather on dash 'pulling'-dscf8369.jpg
The following 3 users liked this post by tberg:
jahummer (06-16-2017), Ozmag (06-02-2017), TX Nigel (06-25-2017)
  #280
Old 06-13-2017, 12:29 AM
Ozmag's Avatar
As I thought Jaguar Australia have declined to assist. The Dealer (Alto Jaguar North Shore) said "their Senior Technician who has worked on Jags for over 20 years had never seen this before on an XK and only rarely on an XF". I suggested they did some research before making such a claim again. I asked what was the solution and they said "new dash at around A$6 to A$7k plus labour. I asked about a trimmer and windscreen removal but their "expert trimmer has now closed up and we just replace".
So I'm looking for a trimmer....
Quick Reply: Leather on dash 'pulling'
