Lifting up a 2009 XKR
Hello everyone.
I am new to this forum and new to Jaguar. I recently purchased a beautiful XKR Portfolio and it is now sitting in my shop. No issues but I want to lift it up on my 2 post lift and check it over. Looking under the vehicle I am not confident as to where to put the jack post. This car is perfect and I do not want to be an idiot by jacking improperly. I tried a search but was not able to find anything. Does anyone have some pics of jacking points. I did not receive the manual yet and would sure appreciate some advice. Thanks in advance!
Thanks, I was able to download the manual and did see this. It looks like this jacks on the rocker panel, not on the lip that sticks down as a lift will do. Perhaps I could build an adapter. I still am concerned jacking on the lip. If I am correct, this is Aluminum, not steel like my other vehicles. The Jag dealer just sent me the following so I at least have a few options here. Sure would love a pic of one on a lift.
Front point is either at the sub frame 18 inches straight under body or at seam just behind front wheels. Vehicle may have mark on side skirt an intentional indent to indicate proper location or little triangles. Rear lift point is in front of rear wheels, under vehicle, 2 19mm bolt heads attached to cross brace. The bolts sit parallel with the seam of the body.
No problem as I have a 4 post lift in my garage and I can see the jack points and the steel plates at the jack points look easy to put either a floor jack or a 2 post extension arms.
