Massive coolant leak
Old 03-15-2018, 09:09 PM
makecopies's Avatar
Default Massive coolant leak
Just pulled up to the drive up ATM and heard both fans running turn the car off and popped the hood and found the expansion tank empty and it looks like it sprayed antifreeze all over the drivers side under the hood and on the drivers headlight.
Just had the car towed. Looks familiar to anyone?
Just had the oil changed at the dealer 4 days ago I would think they would have noticed a antifreeze leak if it was the water pump?
Old 03-15-2018, 09:17 PM
Received 2,577 Likes on 1,783 Posts
From the photo, it appears the water outlet that contains the thermostat has failed.
How many kilometres/miles on the vehicle? Has the water outlet been replaced as it can only go through a finite number of cold and hot cycles before failing.
Old 03-15-2018, 09:19 PM
makecopies's Avatar
I just hit 156k miles today
I was so excited
Old 03-15-2018, 09:26 PM
Has the water outlet ever been replaced? It must be replaced each time the coolant is changed or it is going to fail.
The JLR part number is AJ811793.
Old 03-15-2018, 09:40 PM
makecopies's Avatar
I didn’t see anything like that replaced in the service history.
Old 03-16-2018, 03:42 PM
Ranchero50's Avatar
Yep, XK got the plastic version, //R the aluminum one. My son's Lincoln LS did that same thing a couple times. Same family of engine with a really **** poor thermostat design. It's not self contained like most. The spring pressure pushes against the fiber reinforced plastic pieces causing them to break.
Old 03-16-2018, 07:54 PM
Sean W's Avatar
Received 4,164 Likes on 2,334 Posts
So can you get the aluminum for the XK or is the design different due to SC?
Old 03-16-2018, 08:39 PM
Ranchero50's Avatar
I"m pretty sure it's blower related. Pity really.
Old 03-16-2018, 09:06 PM
steve_k_xk's Avatar
Received 1,538 Likes on 889 Posts
No such luck with the housing they only come in the plastic variety by memory I replaced mine at 40k miles / 7yrs
Sean W (03-17-2018)
Old 03-17-2018, 10:16 AM
There is no aluminium version of the water outlet for the normally aspirated 4.2 engine.
Sean W (03-17-2018)
Old 03-17-2018, 01:07 PM
dsd's Avatar
dsd
dsd is offline
Is it SOP to replace during flush/service or will I need to ask when I go in for standard coolant service?
Thanks!
Old 03-17-2018, 01:11 PM
Cee Jay's Avatar
Received 5,149 Likes on 3,085 Posts
Find someone with a CNC machine and have one cut from billet. OR, have one cast, get a pattern and sell a whole bunch of them.
Old 03-18-2018, 11:14 PM
ralphwg's Avatar
Received 1,180 Likes on 893 Posts
What about 3D printing with an appropriate media?
Old 03-19-2018, 12:24 AM
Cee Jay's Avatar
I'd never trust anything printed to contain pressurized boiling liquid, especially when loss of that liquid would be catastrophic.
Old 03-19-2018, 09:01 AM
Thanks!
You will need to request the water outlet be changed.
The following 2 users liked this post by NBCat:
10XKR (03-19-2018), dsd (03-19-2018)
Old 03-19-2018, 09:38 AM
dsd's Avatar
dsd
dsd is offline
I do 3D printing. CeeJay is right on here, the pressure would be the problem.
The following 3 users liked this post by dsd:
Cee Jay (03-19-2018), ralphwg (03-19-2018), winstonsalemncxk (03-19-2018)
Old 03-19-2018, 06:09 PM
u102768's Avatar
Received 1,484 Likes on 907 Posts
If it works for brake calipers it should be OK for the coolant system
https://arstechnica.com/cars/2018/03...ti-and-porsche
Old 03-19-2018, 06:18 PM
Cee Jay's Avatar
Dunno about you, but I don't have a Titanium 3D printer. I'm sure there has to be pressure and heat while printing, just can't lay powder on top of powder and have it actually work.
Old 03-19-2018, 07:30 PM
Lancer033's Avatar
depends on the quality of 3D printing. They're doing 3D printed rocket engines now that i'm sure see a lot more force than a normal coolant system, just have to pay for it.
Old 03-19-2018, 07:39 PM
Cee Jay's Avatar
Make a mold of the plastic OEM, cast one using alumin(i)um. Cost about $10 and a couple hours work. Course one would need the proper tools.
Quick Reply: Massive coolant leak
