Mileage (odometer) roll back on Jaguars
I had someone ask me today:
With all of the electronics and the re-programming of the Jaguar cars, is it possible for a dealer to roll back the mileage (odometer) on these cars? I responded "I don't know, I am not sure what the re-programming entails". Does any one know the answer to this question? |
It can be done. See CBS2 Investigation Uncovers Odometer Fraud Possibly Affecting Thousands Of Consumers « CBS Los Angeles
Caveat emptor - Buyer beware! |
Originally Posted by richzak
(Post 815587)
.............. With all of the electronics and the re-programming of the Jaguar cars, is it possible for a dealer to roll back the mileage (odometer) on these cars?
A legitimate example of resetting is when a new Instrument Pack is fitted. It's programmed to the vehicle using the dealer diagnostics and, as part of this configuration process, the odometer is set to match the original unit. It could just as easily be set to any mileage ..... Software is becoming more widely available for the less scrupulous to manipulate mileage readings. This is such a problem in the UK that our annual vehicle inspection (MoT) now requires mileage to be recorded. Graham |
Apparently, programming mileage with IDS/SDD requires a form to be submitted to Jaguar Head Office, and it requires a one time password from Jaguar Tech Support.
However, there are other devices out there for resetting mileage that may or may not work on Jaguars. |
There's always a way as it is quite profitable. Best way to avoid this fraud is to get service records. Call the dealer the car was originally sold from to get a head start.Also, look in the service books and door jams for any place the owner may have forgotten to remove past records in order to hide his tracks. I wouldn't want to buy any car that didn't have service records and then I can do the arithmetic. If there is a huge time gap between services or none, that would be a red flag.
When I used Autocheck helping a friend, it alerted me to altered mileage.... Something the basic buyer would not have known....
Not sure about carfax... Just an FYI Vince |
Thanks for the replys.
My own personal CarFax and AutoCheck reports did provide confidence that when buying my 2009 Jaguar XKR Portfolio Edition the mileage was correctly posted as evidenced by the history of the car. I also spoke with West Palm Beach Jaguar to verify all service records. I am glad I paid for the reports and called the dealer. Some potential car buyers may not want to go though this process. I am still not 100% sure of what the re-progamming of the car does or what it entails or why Jaguar dealers do it. Perhaps someone can shed some light on the re-programming issue. |
Originally Posted by bocatrip
(Post 815797)
Car had 8-10K miles a year every year then 2 years it went only 2K total should raise some flags if not supported in paperwork. |
On many cars the mileage is tied to the cluster itself. The cluster can be reprogrammed once to a higher mileage during its first 100 miles of life. After that, it is unalterable. The purpose is to allow replacement clusters to be programmed with the correct mileage.
This is a question that has always concerned me about Jaguars. I'd like to own one, but am put off by the question of mileage resets. Lots of "19.900" and "24,850" Mi cars out there
However, I've discovered something in my BMW 5-series. I do all my own work, including programming and diagnostics via INPA, DIS etc. In the 30+ separate controllers in my car are multiple places where actions are recorded with the mileage at that time. For example, I replaced a battery, and the power management controller permanently records it as 90,000 Km. A new Transmission control unit is recorded (on the unit) as having been installed at 95,000 Km. And so on. If the odometer reads 30,000 km, it's hard to explain the rest of the mileage data. These mileage records would never be altered unless the dealer/owner re-installed all the software in every Control Unit with a record, or hacked the actual eprom records to change them. Doubtful. Do recent Jag XK's have programming software available on the aftermarket that allows reading controller module data? Such packages are available for late model BMW's for less than $100. Could answer the question of hacked odometers pretty quickly. Thanks. |
(Post 815883)
You want the service history and receipts to paint a clear picture with no gaps and with the expected mileage at each record.
In my case, the dealer (West Palm Beach Jaguar) was able to confirm the service appointments and what type servce that was completed, but would NOT provide me with actual copies of the service history in written form. They wanted to protect the name of the previous person who leased the Jaguar. I thought that was very fair. Their verbal records did confirm both the Carfax and AutoCheck records. When I called the dealer service department, all they needed was the last 6 digits of the VIN to retrieve the service records which took only seconds to retrieve. |
(Post 816248)
Most dealers will only confirm the service history. The dealers are prohibited under privacy rules/laws to release copies of the service records in order to protect the previous owners/lessee of the automobile.
(Post 816355)
Was West Palm Beach Jaguar able to confirm the service appointments for a car they themselves serviced or any car serviced by a any Jaguar dealership?
(Post 816248)
(Post 816563)
I bought my XK from Jag dealer and they had every receipt from tires, oil changes, car detailing... Window Sticker... Every penny the owner spent on the car was included with the car to me.
Did the receipts show the previous ownes name who made and paid for the repairs, tires, deatiling etc.? |
(Post 816563)
(Post 816248)
(Post 816758)
Your very lucky....did the dealer actually print the service records and supply them to you, or where they left in the car for you from the previous owner?
Did the receipts show the previous ownes name who made and paid for the repairs, tires, deatiling etc.? Dealership thought the car would sit due to being Seafrost Green, but my saleslady knew that it was the exact car I was looking for. Not necessarily that color (never heard of it before this car), but the overall condition and fully loaded. Bought sight unseen. No inspection, just some good photos. Shipped it enclosed. So far so good. |
(Post 816841)
They were the original receipts with previous owners name and everything. They traded the car in with 17K miles to buy a new XK. Bought and traded in at same dealer.
That was one great thing when purchasing a Lexus. Most Lexus owners will only bring their cars (even after warranty expires) to dealership. The printout I got on my 01 LS430 started in 2001-2010(date I purchased it) covering every dealership regardless of state with mileage and work done. Pages of info to read. My Infiniti is the same regardless of which dealership it is serviced.
