"Creeking" in uneven surfaces
Creaking can be an almost and unlimited list of possibilities. I would start by getting some WD40 or Silicone spray and give every suspension joint, bushing, sway bar bushing, shock bushing and strut bushing a good soaking.....wait for about 30 minutes and see if that helps......it is a $2.00 fix and will almost always improve something. Don't forget the door hinges and latches.
Good luck,
Ron
Good luck,
Ron
Macc (05-11-2017)
Creaking could be just chassis flex.
Never use WD40 oil itself. WD40 is a degreaser and not a lubricant.
Silicone spray, on the other hand, yes.
Good luck,
Ron
Good luck,
Ron
This my last post on this issue:
WD-40's main ingredients as supplied in aerosol cans, according to U.S. Material Safety Data Sheet information, are:
50% "aliphatic hydrocarbons". ...
<25% petroleum base oil. ...
12–18% low vapor pressure aliphatic hydrocarbon. ...
2–3% carbon dioxide. ...
<10% inert ingredients.
steve_k_xk (05-22-2023)
The following 4 users liked this post by GGG:
Keep an open mind to the following:
The issue with the blue can of WD40 is that it creeps/ penetrates, i.e. it wont stay in place.
Compounding to the problem, it is excellent at stripping permanent lubrication such as grease.
The proof of this is that WD40 itself makes better products for our stated application. Such as "Spray & Stay lubrication Gel" which claims to last 12x longer! (inversely you could call the blue can 12x shorter spray and run) Its also interesting it claims to last one year. Wonder what that means about the blue can.
https://www.wd40specialist.com/products/spray-gel
I have some "creaking" emanating from the base of my driver's seat, at the joint where the seat back is hinged to the lower seat. I can actually put my hand on the outside of the edge and identify its source. One of these days I will get down there and lubricate. I use a silicone lubricant that we use in the drapery installation business that is the best I've ever used. It is not typically available in hardware stores but available online. (see below)
https://www.ellsworth.com/products/b...20-oz-aerosol/
There is a source for this sort of noise: in the engine compartment there are stabilizer bars from the firewall to the fender on each side. If the bolts are in any way loose a noise will be transmitted into the cabin, and yes, it sounds as though it comes from behind the dashboard. In severe cases it become a knock rather than a squeak. Try tightening the nuts on the fittings (easily accessible).
The following 3 users liked this post by sov211:
Thanks for posting this. The noise that I've been hearing in my XKR, and subsequently researching the cause, I would describe more as a knock or loud pop right behind the dash. It doesn't happen all of the time, but when it does it usually happens when I'm turning and the street is transitioning to another elevation like into a parking lot or driveway. I will take a look at the nuts on the stabilizer bars this weekend. Cheers!
