Need advise about 4.2 crankshaft!
Hi guys!
Will you tell me is it possible to make grinding work for crankshaft of 4.2 s/c engine? And whether exist are bearings of the repair sizes for 4.2 s/c engine crankshaft? Thank you! |
What does Google say?
Originally Posted by Ranchero50
(Post 2067676)
Miscellaneous. Frankly speaking I am afraid. Someone writes that it is normally to grinding a crankshaft. Someone writes that the surface of a crank is tempered at its manufacturing. And after polishing the shaft will inevitably break. I do not know what to do. |
Pai what is the extent of the damage to this particular engine
(Post 2067886)
Originally Posted by PaiMai
(Post 2067867)
Why do you need a crank .
Did your engine sustain damage ? |
(Post 2068167)
sorry to hear that
With oil starvation your going to need more than simply a crank your entire bottom end will mostly likely be shot and the block will have to be honed , decked to make way for new pistons as they will be scored. The way I see it is you have two options . Option 1- source a second hand engine and simply change it over somewhere in the region of $4-6k Option 2 - full rebuild , very expensive however if you do go down this path whilst in pieces it'd be sourcing down larger pistons increasing capacity . Anyone's guess of how much ?? $8-12k + Lastly what do you mean by a soured reducing valve was the case did the mechanic say this and how did it get there |
Yes, now the engine is ready to pull out from the car. I think that in 2-3 days it will be already possible to examine the engine from within.
Could tell me please, cranks in 4.2 are tempered by currents of high frequency?
Steve will you give me advise please! Bolts on engine 4.2 disposable? Usually what bolts need to change at capital repairs?
Whilst the engine is in pieces I would take a look at the timing chain guides if there is any wear replace .
Also replace the water pump whilst engine is out Obviously new head gaskets and head bolts will also be required Bottom end bearings will should also be replaced on the rebuild |
Thanks! I will follow your advice.
