New Oil choices for 5.0
What do you guys think about 4 new choices for oil now available in USA.
They all meet the current Jaguar spec for 5.0 engine 1.https://www.racecompusa.com/product/...ne-oil-107339/ 2.https://www.ebay.com/itm/JLR-51-5122...4383.l4275.c10 3.https://www.ebay.com/itm/RAVENOL-0W-...L/371451382462 4.https://www.ebay.com/itm/NEW-BMW-Jag...n/361995063214 Thoughts, advise, warnings, ridicule, all welcome. Castrol has become harder to find. |
Oh's Nooooooooooes! Not this again.
No dog in this fight. Just here for the entertainment.
:icon_lurk5: :icon_couch: :icon_munching: |
For Fuch's sakes guys.
Did not even bring up Fuchs Motor Oil which was the 5th choice as I knew the group would snicker. https://www.ebay.com/itm/Fuchs-TITAN...2/292644919559 Have my eye on Jacco Cant find Castrol- this is serious |
Pretty pricey stuff! I can get the Castrol Pro 0-20 at my dealer for under $8 a quart.
I'm glad to see there are other possibilities available. I'm on a road trip at the moment and will visit a Jag dealer in Memphis to pick up a Castrol supply. I'll be looking to see comments about one of these as a possibility in any case though. Just changed oil the other day so I've got tons of time to read what the group comes up with.
Pennzoil Ultra Platinum 5W-20 meets the spec for the cars that require this grade and it can be bought on-line from Walmart for $25 for 5 quarts.
Originally Posted by Don-T
(Post 1936564)
$8 is a fantastic price or any POA based oil. |
Originally Posted by TXFireblade
(Post 1936659)
One thing reassuring is that all 5 companies making this formulation, are all charging about the same price. So this must be expensive to produce.
But I dont care about the money, its the availability. |
I am reading 2015 and UP 5.0L engines for compatibility on these oils. Does this new spec apply to our 5.0Ls? ?
Sorry, too busy to do the research on my own right now but if you already know, please share :) |
Shemp,
Yes they silently went to it. https://topix.jaguar.jlrext.com/topi...50a34ec&page=1 (I agree that it was a step in the right direction, there was an issue of oil not flowing fast enough to the chain tensioner on startup) |
If both (0W-20 and 5W-20) meet JLR lubrication specs, why spend more for the 0W-20? I doubt that the incrementally better fuel economy of the 0W-20 is worth the cost.
Probably depends more on the min temperature your car sees. I never start my engine when it's bellow freezing, so 5W is probably fine for my case
Originally Posted by Stuart S
(Post 1936989)
Originally Posted by BlueXKR-S
(Post 1936995)
I.e. it becomes same as 10w-20 after a while- which was causing complaints You want the 0w in an XKRS that does not see winters- only so as to keep up with Jags latest advancements. (there are other things updated besides the viscosity) |
(Post 1936989)
Just thinking out loud. Dave |
Originally Posted by 10XKR
(Post 1937141)
I agree, and also what keeps the gears going inside my head is that part of the reason I have seen touted for the "0" is due to the tight tolerances of the 5.0...so what about as these engines age and wear with higher mileage. Wouldn't a 0 weight be detrimental vs a 5 weight with higher mileage above say 75K miles?
(Post 1937141)
When the engine has warmed up to normal operating temperature, what difference does it make if it's filled with either 0W-20 or 5W-20? They're the same 20W viscosity when warm.
And I disagree with Q&C's conclusion that "they're both the same money". That depends on where you are. Prices vary by location. |
