Optical Illusion
Queen and Country (01-24-2019)
Sending PM.
The following 3 users liked this post by Cee Jay:
Queen and Country (01-28-2019)
#30
#31
Post this on the thread where the poor bugger's top wont go up.
If it was designed as a convertible originally, how come my chassis has few parts.
#32
#33
Cause it needs no additional parts to stiffen the chassis.
Thats why it seems improbable that the controvertible was designed first.
Unless done by a daft person, it would be easier to eliminate the top and add additional braces than to build a top on a convertible car. Which seems to be the case.
I would further imagine that it would be near impossible to make the lines on the coupe meet so harmoniously unless designed ground up- the inverse would be true of the vert.
#34
#35
It's the coupe we're seeing first, but the XK was initially designed as a convertible. "If you get the convertible right, the coupe will naturally follow," Callum says. "It doesn't always work if you do a coupe and cut the roof off. I didn't want something that looked like a bathtub with a hole in it." The convertible has a cloth roof that stores neatly under a hard tonneau cover. "We looked at doing just one car with a folding metal hardtop like the Mercedes SL," admits Callum, "but that's a three-box car. That's not a Jaguar."
The following 2 users liked this post by PsiFox:
kj07xk (01-28-2019),
#36
Structurally the car was designed with the convertible in mind.
From a manufacturing stand point the cars go through identical processes except for a few parts.
Unlike cars of the 1990's and before where Convertibles were a follow up model, the XK was designed to be both from the start.
From an aesthetics standpoint I am not sure if one came first, or both were being worked on. I would imagine based on the concept car that the coupe was styled first, since they released a concept of a coupe. Doesn't prove anything.
#38
I had noted in magazines that many manufacturers started with both/convertible in mind near the turn of the millennium.
The Porsche 997, and Corvette C6 being two notable examples. I had also noted this was true for the X150.
It would be interesting if some day someone did a "notch back" by making a hard top with the convertible lines.
#39
#40
Side Vent- Functional?
"5. This vent will become a Jaguar design signature. It's functional: There's a low-pressure area behind the wheel that helps draw air through."
So the XKR has two sets of functional vents - one set in the hood (bonnet) and the other set in the front fenders (wings).
kj07xk (01-28-2019)
