Proper burnout method for 4.2 XKR
Old Oct 31, 2019 | 09:02 AM
gkubrak's Avatar
Default Proper burnout method for 4.2 XKR
So I am due for new rear tires soon but first I would like to smoke the crap out of the old ones.
I tried the other day, holding down the brake, and just reving up. But for some reason the RPMs would automatically drop as if the computer was not letting me.
You guys know how to properly burnout on the 4.2 XKR? Should I remove the fuse for traction control? Thoughts??
Old Oct 31, 2019 | 10:27 AM
Cee Jay's Avatar
To totally disconnect the Anti Skid, you must Hold Down the DSC button for longer than ten seconds. "DSC OFF" will appear in the center of the dash. Be Careful! The thing will get squirrely.
Old Oct 31, 2019 | 10:39 AM
Canadacat's Avatar
4.2 not so much, maybe on a corner if you hit it but its not like you stand on it and it shoots you onto a pole, will do a little spin but thats about it. Tires will usually grip pretty fast.
If you want to burn them off go to an empty parking lot turn your wheels and crank it, will spin for days. No guarantee that your steering will not blow a line but it will smoke those tires.
Old Oct 31, 2019 | 10:42 AM
gkubrak's Avatar
Originally Posted by Cee Jay
... Be Careful! The thing will get squirrely.
Can you elaborate?
Old Oct 31, 2019 | 12:35 PM
Cee Jay's Avatar
I was talking about smokin' the snot out of the rears, not 'normal' driving. However, with Trac OFF, you can EASILY smash into trees, poles and slow pedestrians. These cars can get sideways in a hurry.
Yes, it will continue to do the spinny-spinnys until the car reaches traction, but it can get a bit sideways when it finally grabs. Be ready for it, and have enough room for some corrections. The first time I did it right after I bought my XKR I was on a narrow road with a ditch on each side. When I finally got traction the rear end shook the whole car and got be a bit twisted on the shoulder, such as it was. It happens a lot when warming up tires before a 1/4-mile run. I'll find an example...
Old Oct 31, 2019 | 12:45 PM
AlexJag's Avatar
Sponsor
You just need a tune. Before the tune I could barely chirp the tires, now even with wider and stickier tires I can light them up with not applying brakes at all
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Oct 31, 2019 | 05:07 PM
guy's Avatar
guy
Now that you've figured it... what fun, right! I prefer taking corners sideways... has a more drastic look. I always completely disengage that crap.
Old Oct 31, 2019 | 07:18 PM
1 of 19's Avatar
Right turn up a hill I was in 4th gear and doing one he'll of a job destroying the ozone layer when I let off the gas. It was retarded 200+ft and it was still shredding the tires. Note: shut windows. The Sherrif was not near as impressed as I was. Received an unreasonable acceleration ticket. Viewed it like a badge of honor. New tires next day.
User 070620
May 6, 2019 05:22 AM
Frizzle
Aug 17, 2015 03:46 AM
1 of 19
Jan 29, 2015 10:48 AM
JeffereyGreen
May 23, 2011 10:57 PM
Dr_Derek
May 6, 2009 03:16 PM
