2007 XK IPhone Audio options
All,
I’m about to pickup a 2007 XK that does not have the ACM.
Dealer basically said they never worked right and recommended any other aftermarket solution first.
So, any ideas what’s out there? Search is a bit all over the place. Anyone do a Parrot mki9200? Does the infotainment have an aux to work with?
I’m pretty open to solutions be them wired or BT.
Thanks!
Thanks!
I would ask the Forum members who have ACM if they agree with your dealer's opinion and advice.
I believe that the ACM is no longer available as an accessory from Jaguar. It was designed to provide steering wheel control over volume and track and limited touchscreen information, and I doubt that any aftermarket devices can do that. You might be able to find a used ACM on eBay.
I disagree with the dealer and would recommend you invest in one (wait and watch eBay as Stuart suggests or the member posted ads here in the forum).
I think a couple of guys will chime in on interim BT solutions.
I decided to pick up this adapter from Amazon:
But it's since out of stock.
Can charge 2 iPhones/droids simultaneously ( work & personal ) and Bluetooth WAZE, Pandora, and phone calls. Can simply answer phone pressing top button or go fwd/rwd songs Etc...
less than 18 bucks They also have them with the ports on top etc.. Bigs selection..
G/L
G/L
But I think I may be looking at this one as a newer one since I can plug it in from top and not just side... I can always use the other one in my other truck
I disabled the VPN on my cellphone and the link worked! Very interesting!
For those of us who can remember ...
https://m.youtube.com/watch?v=krD4hdGvGHM
Sorry looks like it's currently not available. It's basically the same as this one -
https://www.amazon.com/Wireless-Blue...6CTJR4AFFSZ98F
https://www.amazon.com/Comsoon-Bluet...6CTJR4AFFSZ98F
I never knew that until just now. Thanks for the education. It was only by chance that I turned off my VPN to see if that made any difference, and I was surprised when it did.
I'm like your signature - "I spell stoopid with two O's". It's easier to remember that way so you never make spelling misteaks.
Stuart
Sean,
Stuart
Stuart
I use a roidmi fm transmitter in my glovebox outlet, which will both charge my phone, and will transmit via Bluetooth to the radio so I can play the tunes from my iphone over the car sound system. A bit clunky but it works. The phone itself syncs right up with no problem.
Have ordered an Roidmi!
110reef (01-22-2018)
asternstein
10-16-2015 12:32 AM
Profesormsc
10-16-2013 07:53 AM
Anxious Jim
10-15-2012 06:35 PM
