Rear gearbox mount broken
Old Sep 28, 2025 | 05:34 AM
J.J.'s Avatar
Default Rear gearbox mount broken
Gear changes have been getting progressively harsher, decided to investigate and noticed a broken gearbox mount p/n: XR849534.
My local JLR dealer quoted me 1400€ for part alone. Not going to happen. Neither will I buy URO parts rubbish from Amazon.
Does anyone know if a similar looking part from a newer XF or F-Pace will fit?
Old Sep 29, 2025 | 08:41 AM
luv2fly's Avatar
Seems it's a bespoke part for the XK. URO may be better than nothing and last as long as you own the car. Don't think it's a hard job even if you have to do it more than once. Or a US dealer?
Old Oct 6, 2025 | 08:14 PM
panthera999's Avatar
Buy the URO for $54. The Jag unit needs to be gold plated.
Old Oct 7, 2025 | 09:43 AM
Sean W's Avatar
Per Jaguar Palm beach, the part number you provided fits:
Jaguar S-Type 4.2L V8 A/T Base Sedan
2003, 2004
Jaguar S-Type 4.2L V8 A/T R Sedan 2003, 2004, 2005, 2006, 2007, 2008
Jaguar S-Type 4.2L V8 M/T Base Sedan 2003, 2004
Jaguar XK 4.2L V8 A/T Base Convertible 2007, 2008, 2009
Jaguar XK 4.2L V8 A/T Base Coupe 2007, 2008, 2009
Jaguar XKR 4.2L V8 A/T Base Convertible 2007, 2008, 2009
Jaguar XKR 4.2L V8 A/T Base Coupe 2007, 2008, 2009
Jaguar XKR 4.2L V8 A/T Portfolio Convertible 2008, 2009
Jaguar XKR 4.2L V8 A/T Portfolio Coupe 2008, 2009
Old Oct 7, 2025 | 11:41 AM
J.J.'s Avatar
Took a gamble and ordered one for X250.
If it doesn't fit, at least it was cheap. Fingers crossed!
Old Oct 11, 2025 | 12:42 PM
J.J.'s Avatar
Don't know why, but the part numbers are a mess.
Since I was in a hurry, I ended up getting a used mount from a flood damaged low mileage F-Type. If anyone is interested, part number was C2D38505. Works perfectly, no more clunking when shifting into reverse.
Old Oct 11, 2025 | 01:17 PM
xalty's Avatar
there’s like 1000 variants of trans mounts they all bolt into each other. some are fluid filled some aren’t.
the $80 amazon full set of engine and trans mounts for a 5.0 xf works fine. your engine mounts are definitely broken too if it has more than 50-60k on the clock the emergency strap just stops it from hitting stuff
Old Oct 11, 2025 | 01:35 PM
Circumnavigator's Avatar
Got the 2x engine and 1x trans mounts for my 4.2L on some ibSpot website for $185 a few weeks ago.
PANGOLIN 3PCS Engine Motor Mount Left Right & Trans Mount C2P17845 C2D38505 Engine Mount for 2009 2010 2011 2012 2013 Jaguar XF XJ 5.0L 4.2L”
Jag Indy and generic family shop both quoted $800 for install. Ouch. So gonna go with the Indy.
leo_denmark
May 14, 2023 11:09 AM
71JagXKE
E type ( XK-E )
Mar 6, 2020 11:15 AM
Tasng4
Mark V - X 420G
Mar 15, 2018 10:09 AM
a1lry
Sep 13, 2017 03:36 PM
brinny
May 13, 2016 12:07 PM
