Replace interior lights with led
Hello all,
I'm planning to replace all my interior lights with led-versions. I searched the forum how to do it but I couldn't find any description. Can anyone be of any help how to replace the lights by myself? TiA Ben |
Ben,
I've moved your question from XK Press pack / equipment spec / tech spec & pics FAQ thread. Graham |
Do a search on this forum, its been done before, and I believe the details of the LEDs used was also provided. |
Thx Kj,
I searched the forum but didnt get any results; perhaps my fault using the wrong parameters? Can you help me with it? Grtz Ben |
Here is a thread that I started that should get you started... There are a couple other threads that have great info and different bulb lists that I have used as well...
https://www.jaguarforums.com/forum/x...pgrade-195058/ |
Thx Texas Traveler,
It will help me in some way for sure, but still didnt find a description how to get to the bulbs so I can take the old out and put the led in. Do you have a tip about the search term I should use to find more suitable threads? Thx Ben |
Originally Posted by Someb
(Post 2027005)
Thx Texas Traveler,
Sorry but a horrible harebrained idea to replace interior lights on XK with leds.
The stock incandescent lighting is laboriously designed to: Gently and progressively come on, and go off the same way. All while maintaining the perfect warm hue becoming of luxury. Its bright enough but never a sharp glare. You will go to led lights that: Dont dim progressively, if they dim at all. Dont have the right hue. Dont have the same real lumens- but feel like it due to glare. And may give you Canbus error. I will never forget the first time I saw an XK. The showroom was being closed because they were moving. All cars were gone except the XKR that sat inside the building. The salesman (now just guarding the inventory) had nothing to do and was just fiddling around with the one car. He said in his idleness he was just sitting inside the XK and getting a sense of the space. He was memorized by how much thought had gone into the mood lighting. |
Originally Posted by Queen and Country
(Post 2027116)
And a side note. I just changed all my exterior in my 04. Whenever doing the amber lense or red lenses dont use white, use amber or red leds. The white give a washed out look. The red actually look pink if you use white leds.
I changed mine purely from a standpoint of continuity since mine has LED: tail lights, DRL's number plate lights and Xenons, IM(not so H)O it made sense to carry that through to the interior. All my interior bulbs inc glovebox, centre console, trunk and under dash all changed for around £10 and (IIRC) 8 bulbs.
No CANBUS errors in 4 months :) I still need to change the bulbs in the wing mirrors but was advised that defused LED's were better and I've been unable to locate them this side of the pond....yet. |
Hi Mark,
I have send you an PM on the luggage item. Did you get any further with purchasing the luggage bags or can you provide me with the address of the manufacturer. Thx in advance. For all other reactions to my post; mayby i will only change the bulbs in the boot and under the dashboard ;) Grtz and again thx Ben |
I'm with Q+C on this, love the warm look. Actually have been replacing the LED and CFL's in my house with the vintage style LED's and love the color.
I looked at changing the instrument cluster LEDs to blue but they are soldered in place. Reward isn't worth the pain since if I screw up that board the car is bricked. |
I can give a piece of advice based on my experience. It is: buy the best light strips, not the cheapest. You’ll waste the money anyway, but if you buy a cheap first, you’ll waste it twice. I wanted to find some quality stuff for my car after throwing cheap LEDs into the garbage (they broke for an unknown reason on the fifth day of usage). I’ve found car interior lighting on the internet and decided that these are perfect. And I’ve never regretted installing them. My car became so atmospheric and cool inside! Now long trips aren’t so boring and similar to me. I’ve been using it for three months, and they’ve never broken. I’m completely satisfied
Originally Posted by SnuseDrake
(Post 2537603)
Do you have any pictures with the new lighting? Love to see your updated look. TIA |
