Satellite Radio issue question
Okay so in my 2007 xk, I have lost the Sat radio signal. I replace the antenna, with same results..I replace the Sat Module..with same results..so Im assuming its the cable...my question is, can I just plug in a sat antenna directly into the module to see if my cable is bad?? and can someone point me to the actual connection on the module to bypass the cable to??
thank you very much
al
thank you very much
al
qwiketz
11-01-2018 03:01 PM
bluesman78
04-26-2010 01:25 AM
SuperV8Jag
01-29-2010 04:41 PM
