SDD How to
Old Apr 25, 2021 | 12:31 PM
jackra_1's Avatar
You have to go thru a fault diagnosis procedure where you select a fault going down a "tree" of selections and then select recommendations.
From those recommendations you should be able to run any that you want.
Old Apr 25, 2021 | 06:49 PM
V7Sport's Avatar
Originally Posted by Wingrider
Was looking for the IDS/SDD on a disk or USB.
Trying to steer clear of the web downloading, all together.
A friend of mine is trying to help me.
Download the V130 software, but is having problems.
I was looking to just purchase it, the V130 IDS/SDD outright.
So the CD, or USB, would be usable on any designated computer.
Laptop or tower computer, would work.
Because the Mongoose cord is more than 12' long.
Wingrider
Try this link: https://www.jaguarforum.com/threads/...0/post-1101712
I know it requires an internet connection to download various SDD versions but also contains a lot of info on getting SDD running.
I was successful in getting V138 running on a MacBook Air virtual machine using Windows XP so if I can do it, anyone can!
Old Aug 10, 2022 | 11:27 AM
nebelfuerst's Avatar
I also entered symptomes often manually. This way you see recommendations for that topic.
I did so to see all available procedures for TCM. ( I never found a procedure overview.)
With my cloned mongoose, I flashed TCM, ECU, airsuspension, door modules without problems.
It just took very very long, so you must have your battery supported to avoid powerfails.
Compared to car-software for other brands, SDD is very very good, because others are even worse.
Old Oct 12, 2022 | 10:55 AM
kabu XJR's Avatar
Default SDD.. how to use
Originally Posted by Aarcuda
What version SDD are you using? Which device are you connecting to your DTC? Give us some background information to know what you have done and what you’re trying to do it with. I use SDD version 131.03
Can you guys shared that SDD PROGRAM?. or how much is it?
Old Oct 12, 2022 | 11:03 AM
jahummer's Avatar
There’s various sources for the kits
https://www.britishdiagnostics.co.uk...s-sdd-v138-kit
https://www.jlridssddmongoose.com
nebelfuerst
General Tech Help
Jul 29, 2025 05:28 PM
Box
Oct 5, 2023 07:51 AM
tbaxl
Mar 16, 2020 08:50 AM
sayitaintso
Jan 29, 2018 07:04 PM
barnter
General Tech Help
Apr 5, 2016 01:00 PM
