SDD How to
You have to go thru a fault diagnosis procedure where you select a fault going down a "tree" of selections and then select recommendations.
From those recommendations you should be able to run any that you want.
Was looking for the IDS/SDD on a disk or USB.
Trying to steer clear of the web downloading, all together.
A friend of mine is trying to help me.
Download the V130 software, but is having problems.
I was looking to just purchase it, the V130 IDS/SDD outright.
So the CD, or USB, would be usable on any designated computer.
Laptop or tower computer, would work.
Because the Mongoose cord is more than 12' long.
Try this link: https://www.jaguarforum.com/threads/...0/post-1101712
I know it requires an internet connection to download various SDD versions but also contains a lot of info on getting SDD running.
I was successful in getting V138 running on a MacBook Air virtual machine using Windows XP so if I can do it, anyone can!
I did so to see all available procedures for TCM. ( I never found a procedure overview.)
With my cloned mongoose, I flashed TCM, ECU, airsuspension, door modules without problems.
It just took very very long, so you must have your battery supported to avoid powerfails.
Compared to car-software for other brands, SDD is very very good, because others are even worse.
There’s various sources for the kits
https://www.britishdiagnostics.co.uk...s-sdd-v138-kit
https://www.jlridssddmongoose.com
