I don't think this is rocket science; and I don't think Jaguar dealerships have practical experience in seat cushion swaps. You could dig around with Jaguar parts catalog'fiche and try to determine the part numbers for the seat cushions. Obviously, if the part numbers are identical, then a swap is possible. But even if the part numbers are not identical, don't give up as the seat cushions may still be swapped with a little imagination.
It is not difficult to remove the seats - just four fasteners hold each seat; and a complicated electrical plug.
I would remove both seats and put them on a workbench, examining them closely. You may be able to puzzle out how to remove the seat cushion, and then compare them side-by-side. Both cushions should have heating elements, so there should be some sort of electrical connection. The cushions should use the same wiring harness, but this is Jaguar.... A shop manual will help some, but don't expect direct information on this kind of swap.
