Sponsored by: DashLynx
Service Required Message
Old 06-29-2018, 01:15 PM
TexasTraveler's Avatar
Originally Posted by Cee Jay
Dunno. I'd assume the ECU knows you're not far from the 12 month period and it's giving you a heads-up. Me, I get nowhere NEAR any 15k miles per year, so that's right-out.
It won't be 12 months until October.... Going forward I won't drive that much either. Although I received a full history of the vehicle from original owner, I wanted to get to know the car and find out as much as I could about it myself and of course because I enjoy driving it... Well since I have everything to do it, I guess she will be getting an oil change this weekend...
edited: had to read the literature you posted a few times for it to sink in, as to what it meant... so it's not just mileage but "driving style and conditions" that determine oil change interval. So I am guessing my spirited driving has shortened the cycle this go round...
Old 06-29-2018, 01:16 PM
Originally Posted by Queen and Country
Its not based solely on mileage or time, that would be same as a sticker reminding you when to change the oil.
Its based on an algorithm. (start-stop vs hyw is one I am aware) the computer takes all that into consideration.
Another one is air temperature.
Interesting, I have not heard that before...
Old 06-29-2018, 01:29 PM
Queen and Country's Avatar
Received 2,380 Likes on 1,607 Posts
Its been subject of lawsuits and controversy in more mainstream brands.
Old 06-29-2018, 01:52 PM
GGG is offline
Received 16,799 Likes on 12,168 Posts
From my 2015MY XK Owner's Handbook:
My XK is due the next service in 27 Days and has covered 4858 miles since the last one. The Service Interval Indicator is NOT displayed in the Message Centre.
One reason for a false countdown being displayed would be if it was not reset at the last service.
Old 06-29-2018, 01:57 PM
shemp's Avatar
But most people fall under the simple rule of x-miles/x-time.
Some manufacturers have abandoned these algos and others claim to be more clever.
My GMC Yukon says it counts crank shaft revolutions and lights up the change oil light after x revolutions. Time is not measured. Usually about 5000 miles for me.
My XK light came on after about 50 weeks since the last reset! (about 4000 miles) Pretty much perfect timing
Old 06-29-2018, 02:30 PM
Amazing the information you can get from the owners manual... I guess I should pick it up and read it before posting another question...
Old 06-29-2018, 02:38 PM
Cee Jay's Avatar
Received 5,160 Likes on 3,090 Posts
Never mind
Last edited by Cee Jay; 06-29-2018 at 11:54 PM. Reason: I don't want to be snarky (right now)
  #28
Old 06-29-2018, 09:18 PM
XJDanny's Avatar
Originally Posted by u102768
SSM71850 infers that the procedure has changed from the 2014MY on all models (XK X150 14MY from VIN B52041).
This is the process for the 2014 on F-Type, XJ and XF petrol models so see if it works on yours and report back:
1. Set the ignition to the ON position.
2. Open the hood.
3. Open the drivers door.
NOTE: A service resetting message will appear on the instrument cluster.
4.Fully depress both the accelerator and brake pedals and hold for 10 seconds.
5. Set the ignition to the OFF position.
6. Set the ignition to the ON position and check the message has been cleared.
7. If the message remains, repeat the process.
I tried doing this several times too but it didn’t work. Why can’t Jaguar make it a straight-forward procedure?? I guess I’ll ask the dealer. :-/
Thank you for the suggestion! :-)
u102768 (06-30-2018)
Old 06-30-2018, 12:57 AM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
They probably have a plug-in tool that does it. (You could probably buy one but won't be cheap.)
  #30
Old 06-30-2018, 03:34 AM
GGG is offline
I'm fairly sure this was a menu option in Jaguar SDD when I was checking my XK for DTC history last month but I'm not sufficiently curious to go and hook up my laptop to find out for certain.
JagV8 (07-01-2018)
  #31
Old 06-30-2018, 04:58 PM
XJDanny's Avatar
The reset procedure is as follows:
1. Press and hold the rear fog lamp switch (before the ignition is on).
2. Press the start button without applying the foot brake (do not start the engine)
3. Release the rear fog lamp switch (1sec)
4. Press and hold the trip computer cycle switch (within 1sec).
5. Press and hold the rear fog lamp switch. (within 1sec)
6. Continue to hold the trip computer and rear fog lamp switches.
7. The message center should display "resetting service mode" and then "service mode reset"
8. Release the trip computer and the fog lamp switches and turn the ignition off.
Now, when you do this, it must be in a nice, even pace to work well. Pretty much on a one-second cadence. Also, it is helpful to practice these steps a few times until a good rhythm is achieved, then do it for real. Seriously.
Well, I tried these steps again and it worked! Finally, after like six months my service light is out. I think what I was doing wrong was I was trying to time each step at one second rather than less than a second. Cee Jay’s instructions say within one second but I misread them as being one second. So this procedure works for a 2014 MY even though other 2014 MY Jags have a different procedure.
Thank you for for the help, Cee Jay!
The following 3 users liked this post by XJDanny:
Cee Jay (06-30-2018), Ngarara (07-01-2018), u102768 (07-01-2018)
  #32
Old 08-16-2018, 09:36 AM
Resurrecting this thread because the service required indicator showed back up last night and again this morning. Car has been sitting for about a week and half since last driven. It has been 326 miles since oil change and resetting the indicator. Does anyone know why this would pop up in such a short distance. checked oil level and it is where it should be, battery is on ctek maintainer and while driving to work today had a steady 13.2-13.5 voltage reading on fusion app. Just to be clear the service required displays right at start up and then goes away within a few seconds.
  #33
Old 08-16-2018, 11:42 AM
Cee Jay's Avatar
How long has it been since last reset? Mine pops up ever year regardless of mileage.
When is the last time you did a Hard Reset, or had the battery disconnected?
Dunno, just throwing ideas out there.......
  #34
Old 08-16-2018, 01:02 PM
I reset it 326 miles ago, couple months with oil change and have not had battery disconnected or done a hard reset in that time...
  #35
Old 08-16-2018, 02:20 PM
Received 2,183 Likes on 1,355 Posts
Originally Posted by texastraveler
resurrecting this thread because the service required indicator showed back up last night and again this morning. Car has been sitting for about a week and half since last driven. It has been 326 miles since oil change and resetting the indicator. Does anyone know why this would pop up in such a short distance. Checked oil level and it is where it should be, battery is on ctek maintainer and while driving to work today had a steady 13.2-13.5 voltage reading on fusion app. Just to be clear the service required displays right at start up and then goes away within a few seconds.
because theres a bulletin about service reminder not showing up and reflashing the instrument pack. But also read that as reminders that reset and come back on in a couple days (customers claim we didnt reset, we do and reminder off but comes back on )
orrrr the reminder wont reset at all.
All 3 really apply
  #36
Old 08-16-2018, 02:34 PM
All 3 really apply
So do you suggest that the instrument pack needs to be reflashed? Or should I just reset reminder when it pops up, since I can change oil based on mileage?
  #37
Old 08-16-2018, 05:04 PM
shemp's Avatar
All 3 really apply
This happened to me once. Oil changed at dealer, Dealer reset message. Next day it came back on. Dealer reset it again. All good Came on almost exactly 1 year later this past April. Changed oil, reset message, still off
  #38
Old 08-17-2018, 10:14 AM
Up to you, the fix is a software update just like our phones and pc. Or you can manual reset again and see what happens
TexasTraveler (08-17-2018)
  #39
Old 08-17-2018, 11:44 AM
Is the software update something I can do thru SDD or does it need to go to dealer?
  #40
Old 08-17-2018, 12:13 PM
Dealership is like the Church...
You can be a rebellious atheist all you want,
Sooner or later, everyone without exception has to deal with the maker's representatives, the maker designed it so.
Quick Reply: Service Required Message
