Slow battery drain
Old Sep 5, 2025 | 01:36 PM
  #41
Cee Jay's Avatar
Originally Posted by kj07xk
@Cee Jay I now recall you said that, and scrolled back to reread your post. Does that only happen with the passenger door, or even with the driver door if you don’t have your key? Does it happen both top up and down?
I often go to the garage and open the driver door without the key nearby. Never tried the passenger door, as it’s next to the wall.
Either door or the boot. Never tried the bonnet that I can remember. Top up or down.
Old Sep 5, 2025 | 01:41 PM
  #42
Cee Jay's Avatar
Originally Posted by Circumnavigator
Yes the damn wall. The bane of every DIYer’s existence.
Right???
Old Sep 5, 2025 | 08:19 PM
  #43
wymjym's Avatar
Show off
wj
Old Sep 5, 2025 | 09:51 PM
  #44
Stuart S's Avatar
Your driver's door is smack up against the wall! How do you get out? Big shoehorn? Climbing over the transmission tunnel is too risky to your manhood! Why do you think it's called the J hook? Now I know why you leave the top down - so you can stand up while struggling to get out. Am I right?
There's a better way, and you can leave the top up.
Back into the garage so the passenger door is as close as possible to the wall. Your XKR will still be the same distance away from your wife's car, but it'll be much easier to get in and out of. You can use your pool noodle to protect it as I previously explained in my Post #64.
Old Sep 5, 2025 | 10:37 PM
  #45
Circumnavigator's Avatar
Haha @Stuart S thats a hoot.
i pull/back her in based on which side I need access to for what I’m gonna work on the next day.
Today it was replacing the clips on the back seat center part and removing fuse 19 for a car show.
I’m tall and thin. So I can open the door and squeeze out. Tonight I pulled in so I can get to the rear end. Just hoping there are jack point markers on the rear. Haven’t looked yet. Going to look at the rear suspension.
I’ve set aside a few of the pool noodles for car use.
Old Sep 6, 2025 | 01:46 AM
  #46
kj07xk's Avatar
No jack points on the rear. Just on the sides, between the wheels.
Old Sep 6, 2025 | 07:13 AM
  #47
A6Gator's Avatar
Removing Fuse 19? Is that an XKR thing or does it work on XKs too?
Old Sep 6, 2025 | 07:39 AM
  #48
guy's Avatar
guy
Look at your fuse box description in the Owner's Handbook. I think you will find there is no Fuse 19 to remove from the Rear Fuse Box.
Old Sep 6, 2025 | 09:14 AM
  #49
Stuart S's Avatar
Click the link below for everything you need to know about Fuse 19 and the Active Exhaust on the Supercharged X150 4.2L and 5.0L models. XK models are normally aspirated and don't have the Active Exhaust.
https://www.jaguarforums.com/forum/x...se-19-a-87400/
Stuart
Old Sep 6, 2025 | 09:49 PM
  #50
CurtJ's Avatar
I'm picturing a Magnum PI style leap into out out of the driver seat.
Adworboys
Sep 1, 2025 09:58 AM
rflorey
Oct 17, 2022 01:42 PM
drboz5750
Jun 28, 2021 02:14 PM
Peter 2700
17
Nov 25, 2020 10:13 AM
Benztojag
May 20, 2013 08:30 AM
