Starting Issue
Had not used the car for a couple of weeks. Battery fully charged on CTEK. Car struggled to turn over as if starter motor was slightly jammed but started. Also power steering not working fully. After 20 miles started normally and power steering normal. Since done 100 miles and car is as new. Has done this once before several months ago. Any thoughts would be helpful!
That's your cars way of telling you that you need to drive it more often. Honestly, without regular exercise these things are to be expected.
I almost think you would be better off pulling the battery if you are going to leave it sit for a month or more vs. have it electronics 'asleep' that long. The car is always pinging the key fob and waiting to wake up. |
I can understand the point you are making but don't believe a two week holiday is a lay up.
From personal experience, a battery tender indicating 'charged' does not mean that the battery has it's full cranking amperage. Yours, if the original, is now in the age range that might need replacement.
Charged = no more useful power is going in. If the battery is below par, it's charged as far as it can be but not like new. If it's almost dead, it's almost dead. Load test it and see?
Try pressing the START button before stepping on the brake pedal. It might start faster that way.
Originally Posted by Stuart S
(Post 1748819)
Cee Jay,
My 2007 LS460 was the same. I thought all cars worked that way and didn't realize that you could press the START button before stepping on the brake pedal until my Jaguar service advisor told me to try it after my car wouldn't start. I was sitting in my XKR chatting with him after having routine service and must have inadvertently pumped the brake pedal, and when I stepped on the brake and pushed START nothing happened. Pressed START then tapped the brake pedal and it started right up. Been doing it that way on both my Jags ever since. Stuart |
Don't worry about it ,mine did it today, and it is on trickle charge every night, next to new battery and a daily driver these cars are known for electrical glitches, you probably get in one day and you'll have no power at all, then in a few minutes it will spring into life. The joys of owning an xk
+1 for Stuart S. Powerhouse, welcome back were you on holiday?
I'm the opposite of Powerhouse. My 2009 XKR is not a daily driver and I've never had any electrical gremlins. That's because I have always kept it on a battery maintainer when garaged and locked the doors.
Originally Posted by ralphwg
(Post 1749008)
(Post 1749119)
